Help with Error 400: Bad Request
Please help. I have scoured the blogs for anything that might help and tried everything I can understand to try and I still end up with the same problem. 400: Bad Request everytime I try to access my Home Assitant from my domain. I am using AdGuard for DNS and DHCP, NGINX Proxy Manager for proxy, Let’s Encrypt for the certificarte, and cloudflare for my host. I have added in to my configuration.yaml:
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.30.32.1
- 127.0.0.1
- 10.0.0.2
and nothing seems to work. I am at my rope’s end. I don’t know what logs I should post here to help show what’s going on so any direction would be helpful. I know I’m not the only one who has faced this issue and it seems that for most everyone adding in the above has solved the problem. I am using a RPi 4 8GB with a 500 GB SSD connected to my TP-Link router with the appropriate ports open. I have followed all the instructions and everything was working perfetly until the need to add the trusted_proxies section to configuration.yaml. Thank you for your time.
Show the error in your home-assistant.log. It contains the IP you need to add to trusted_proxies.
Here is a copy of the log entry when I tried to access form the outside:
2021-09-25 19:25:54 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.70.98.43
2021-09-25 19:25:54 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.70.98.135
2021-09-25 19:25:55 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.69.35.164
As you can see they are all from different IP Addresses and one from another subnet.
Here’s another one a little later:
2021-09-25 19:42:09 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 108.162.215.105
2021-09-25 19:42:09 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.69.35.164
2021-09-25 19:42:11 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 108.162.215.105
2021-09-25 19:42:11 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.69.35.164
2021-09-25 19:42:11 ERROR (MainThread) [homeassistant.components.http.forwarded] Received X-Forwarded-For header from an untrusted proxy 172.70.98.43
So, yeah. No one else has run across this before from my research. I hope this means something to someone because I’m stumped.
You use the
proxies ?
trusted_proxies:
  - 172.30.32.1
  - 127.0.0.1
  - 10.0.0.2
#log reported ipv4
  - 162.158.159.139
  - 172.69.55.59
  - 141.101.76.195
  - 141.101.98.91
  - 141.101.99.102
  - 141.101.105.87
  - 141.101.105.99
#cloudflare ipv4
  - 103.21.244.0/22
  - 103.22.200.0/22
  - 103.31.4.0/22
  - 104.16.0.0/13
  - 104.24.0.0/14
  - 108.162.192.0/18
  - 131.0.72.0/22
  - 141.101.64.0/18
  - 162.158.0.0/15
  - 172.64.0.0/13
  - 173.245.48.0/20
  - 188.114.96.0/20
  - 190.93.240.0/20
  - 197.234.240.0/22
  - 198.41.128.0/17
#cloudflare ipv6
  - 2400:cb00::/32
  - 2606:4700::/32
  - 2803:f800::/32
  - 2405:b500::/32
  - 2405:8100::/32
  - 2a06:98c0::/29
  - 2c0f:f248::/32
Thanks, @francisp. I’ll give anything a try at. This point. I’ll let you know.
@francisp that did the trick! Thank you so very much. It never occured to me that the revers proxy could also be on the host’s side too.
Just wanted to jump in here and also say thanks @francisp too, as that sorted it for me as well!
Thank you, this has had me chasing my tail for the last 24hrs.
The only change I had to make was this though.
trusted_proxies:
  • 172.30.32.0/23
  • 127.0.0.1
  • 10.0.0.2
  • internal ip
Also wanted to say thank you, this saved me time and a lot of hassle identifying what was wrong with my apache proxy. Thank you.
I am going to cry. I can’t get this to work no matter what I try. here’s my setup:
  1. TrueNAS HomeLab on 192.168.61.41
  2. Nginx installed within TrueNAS, accessible through 192.168.61.41:10583 (for port 80 and 10584 for port 443
  3. HA installed on RPI at 192.168.61.154:8123
  4. HA config.yaml includes:
  trusted_proxies:
    - 173.245.48.0/20
    - 103.21.244.0/22
    - 103.22.200.0/22
    - 103.31.4.0/22
    - 141.101.64.0/18
    - 108.162.192.0/18
    - 190.93.240.0/20
    - 188.114.96.0/20
    - 197.234.240.0/22
    - 198.41.128.0/17
    - 162.158.0.0/15
    - 104.16.0.0/13
    - 104.24.0.0/14
    - 172.64.0.0/13
    - 131.0.72.0/22
  1. Nginx UI panel config:
Keep getting 400 bad request. If I enable SSL settings then I get too many redirects.
I will pay someone to solve this problem of mine, that’s how desperate I am.
have you tried adding - 192.168.61.41 to the trusted proxy list? That should work as it’s your LAN proxy IP if I’m following you correctly.
I had to add ::1 for IPv6. I had the IPv4 IP you mentioned and the moment I added the IPv6 redirect, it magically started working
Hi guys after weeks of f***ing around. In your Nginx proxy server add the following to clear the X-Forwarded-For information passed on by Cloudflare:
proxy_set_header X-Forwarded-For “”;
