Help with error in log
Hi, I’m getting long list of errors in my log with associated services missing. Below is the first error in the log. I can paste the full log in if it helps anyone figure out whats gone wrong. I have HA running on a RP3 using the AIO installer and I recently upgraded to python 3.5. It was working ok and these errors have just popped up. Any ideas?
2017-10-16 20:43:05 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
    raise err
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
    sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
This is the full log
    raise err
    sock.connect(sa)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 345, in _make_request
    self._validate_conn(conn)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 844, in _validate_conn
    conn.connect()
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connection.py", line 284, in connect
    conn = self._new_conn()
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connection.py", line 150, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6630df90>: Failed to establish a new connection: [Errno 110] Connection timed out
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/adapters.py", line 438, in send
    timeout=timeout
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/connectionpool.py", line 649, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/packages/urllib3/util/retry.py", line 388, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.simplepush.io', port=443): Max retries exceeded with url: /send (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6630df90>: Failed to establish a new connection: [Errno 110] Connection timed out',))
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/core.py", line 1025, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/notify/__init__.py", line 143, in async_notify_message
    yield from notify_service.async_send_message(**kwargs)
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/notify/simplepush.py", line 59, in send_message
    send(self._device_key, title, message, event=self._event)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/simplepush/__init__.py", line 15, in send
    requests.post('https://api.simplepush.io/send', data = payload)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/api.py", line 112, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/sessions.py", line 518, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/sessions.py", line 639, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/requests/adapters.py", line 502, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.simplepush.io', port=443): Max retries exceeded with url: /send (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6630df90>: Failed to establish a new connection: [Errno 110] Connection timed out',))
This indicates that it is something to do with your simplepush configuration. I use this service and had a notice from them yesterday, so the service should be operational.
I just tried to remove simplepush completely from my setup but I still get the error. There are other services throwing errors as well so I suspect its to do with python 3.5 but I have no idea how to fix it :frowning:
If python 3.5 was working, but has now stopped, it is more likely to be a network problem.
Try to start with the simple things. Can you ping these sites from the command line on your pi - as homeassistant user. For instance
ping simplepush.io
and perhaps using the curl examples from simplepush website to check to see if https is working.
@gpbenton ok I’ve tried to ping simplepush.io and not receiving and response. Pushover.net and pushbullet.com are both responding. Can you tell me where to go from here?
Edit: After a lot of mucking around it looks like all my internet based sensors were playing up along with simplepush. Looks like my isp was having issues. Thanks for your help though
