Hi Guys,
i have this error in log file, i can’t figure it out to which component it’s related to, error code:
2020-09-20 14:35:25 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/template/template_entity.py", line 264, in _async_template_startup
result_info = async_track_template_result(
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 792, in async_track_template_result
tracker.async_setup()
File "/usr/src/homeassistant/homeassistant/helpers/event.py", line 518, in async_setup
self._info[template] = template.async_render_to_info(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 306, in async_render_to_info
render_info._result = self.async_render(variables, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 285, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.8/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.8/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
can someone help ?
Tx.
