Juggler
(SR)
1
I’m trying to write an action with an event template. Without the template, the event looks like:
- event: homeassistantCube
event_data:
notifications: [{title: 'Goodnight security', severity: 'warning', options: {detail: 'All is well... sleep tight', dismissable: 'true'}}]
I would like to add the following into the above as a random integer: {{ range(1,99999) | random }}}
, so the event would look something like:
event_data_template:
notifications: [{title: 'Goodnight security', severity: 'warning', options: {detail: 'All is well... sleep tight', dismissable: 'true', serverId: {{ range(1,99999) | random }} }}]
I know the above is incorrect, but I cannot figure how to escape it properly. Can any Jinja ninjas help me out?
J.
Why do you say that? I just copied and pasted it into the Template Editor and it seems to work fine. Are you seeing an error somewhere?
EDIT: Actually, you may be right. You could try:
notifications: [{title: 'Goodnight security', severity: 'warning', options: {detail: 'All is well... sleep tight', dismissable: 'true', serverId: '{{ range(1,99999) | random }}' }}]
or:
notifications:
- title: Goodnight security
severity: warning
options:
detail: All is well... sleep tight
dismissable: 'true'
serverId: "{{ range(1,99999) | random }}"
Juggler
(SR)
3
That did the trick… thank you!
