Help with ESPhome and a SSD1306 display scrolling text
I have only been using HA only for a couple of months and have managed to build several simple sensors with esp home.
I had an idea for my father in law with a node mcu and a SSD1306 display for his model railway.
All I wanted to do was display the current time and date, along with a couple of lines of text that scroll the text along,as it is too long to be displayed in 1 line
The time and date work fine I just cannot figure out how to scroll the text, If someone could point me in the right direction I would be very grateful
this is the code I am using at the moment
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "my wifi"
  password: "my wifi password"
  ap:
    ssid: "Displaytest Fallback Hotspot"
    password: "Wom7XF0q85zk"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
  sda: D1
  scl: D2
  scan: false
  frequency: 700khz
font:
  - file: 'Lato-Regular.ttf'
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    reset_pin: GPIO16
    address: 0x3C
    update_interval: 5s
    lambda: |-
      it.fill(0);
      it.strftime(0, 0, id(my_font), "%H:%M                       %d-%m-%Y ", id(sntp_time).now());
      it.print(20,15, id(my_font), "Killamarsh Central");
      it.print(0,35, id(my_font), "The next train to Sheffield is in 12 minutes arriving at platform 3");
      it.print(0,50, id(my_font), "The 7.45 from Chesterfield is delayed and will be arriving at 8.20");
Thank you.
