Hi. I am trying to control a set of HVAC dampers. The damper has 3 wires, common, open, close, and requires 40v for 15 secs to fully move from open to closed. I am using a lilygo t-relay-8 as the controller (see here: https://www.aliexpress.us/item/3256804149327347.html?gatewayAdapt=bra2usa&_randl_shipto=US)
I have the relays set up so that for the first damper, relay1 switches the power on when closed, and relay2 controls open/closed, for the second damper, relay 3 controls the power, relay 4 controls open closed, etc…
What I would like is to have a switch exposed to home assitant for each damper, and when it is commanded to open or close on that state change, the power is applied for 15 secs, and then is shut off.
Here is the yaml I have so far for the relays and their logic using a template switch:
switch:
- platform: gpio
pin: GPIO33
id: relay8 # damper 4 open/close
- platform: gpio
pin: GPIO32
id: relay7 # damper 4 power
restore_mode: RESTORE_DEFAULT_OFF
- platform: gpio
pin: GPIO13
id: relay6 # damper 3 open/close
- platform: gpio
pin: GPIO12
id: relay5 # damper 3 power
- platform: gpio
pin: GPIO21
id: relay4 # damper 2 open/close
- platform: gpio
pin: GPIO19
id: relay3 # damper 2 power
- platform: gpio
pin: GPIO18
id: relay2 # damper 1 open/close
- platform: gpio
pin: GPIO5
id: relay1 # damper 1 power
- platform: gpio
pin: GPIO25
id: redled # onboard LED - damper active
cover:
optimistic: true
open_action:
- switch.turn_off: relay2
- switch.turn_on: relay1
delay: 15s
- switch.turn_off: relay1
close_action:
- switch.turn_on: relay2
delay: 15s
When trying to install, I am getting this error:
RROR Error while reading config: Invalid YAML syntax:
while parsing a block collection
in “/config/esphome/damper-control.yaml”, line 72, column 7:
expected , but found ‘?’
in “/config/esphome/damper-control.yaml”, line 74, column 7:
delay: 15s
I don’t understand the error - I have no ? in the yaml, and I don’t get why the there is a yaml syntax error for the switch.turnoff command when the other turn on and turn off commands don’t throw errors?
I’d love some help in figuring out why this is not working.
Thanks!
