Help with Everything Presence Pro
Hello everyone,
I have problems with my everything presence sensor pro. Specifically the Occupancy sensor never switching off.
The reason being that mmWave Presence as well as the static Presence sensors always say detected, even when there is nothing around.
Even with Static Presence Sensor Enable turned off, all the sensitivity settings on zero, it refuses to clear.
In the zone configurator add on (app) it shows no targets and Tracking Presence is on Clear.
I have tried rebooting, power cycling, reflashing the firmware via browser and still I have the same problem.
Has anyone had similar problems and can point me in the right direction?
Thanks for the help
I have the issue where it’s going on/off every 2sec. I need to troubleshoot this still and haven’t had time.
To rule out something in the room causing the trigger, drop the sensor in a box (opaque) and monitor the logs for a few minutes. I had to do this with a sensor (admittedly not a MMW) that was being triggered by reflections off the light coming in a window JUST right. At least thats what I’m saying it was.
By removing air currents and any possibility of light causing one of the other sensors to go off, you can at least rule out the device. I actually JUST did this with my neighbors drive way light as well. Something in their fixture would move with the breeze (webs likely) and trigger the motion sensor.
Basically this is a simple troubleshooting process. Start at one end of the chain, and test everything til you find what isnt working. The simplest end of the chain is the sensor end (usually).
Good luck.
After flashing it I left it in my office as the living room space is quite large and I have pets.
In the office it’s staring at a corner of an outdoor wall. Nothing is moving there and there are no electronics either. I’d rule out any interference in that area.
The sensor is still on detected all through the night. :frowning:
Thanks for the idea though!
Think hard on it… I say this because if my ceiling fan is turned on, my presence sensor will show as detected.
You need to post any detailed and/or specific information regarding your setup/wiring, seeing your code/config would be helpful, also seeing the lpg outputs that show whenever these false positive triggers are happening, etc etc… Just posting a short novel as your question isn’t really all that helpful or even relevant information. We need specific facts/data/logs/pictures/ product links/etc that are for your project right now.
Hi, try removing the front panel. Some units have a physical defect.
I have a similar issue with my robot vacuum—specifically the Dreame X50 Ultra—though it might be easier to resolve. It triggers a false “presence” detection on my EP Pro.
Does anyone know of an ideal setup for the EP Pro that would prevent the robot from triggering a “presence” detection with this sensor? The sensor setup consists of 2 mmWave detectors and 1 PIR detector.
I’ve got the same issue with 2-sec false presence on my Everything Presence Lite. I tried 3 types of MW sensors without success.
For me, it seems to be a defective main board. I’ll try these MW sensors with DIY ESP board to check them later.
