I’m trying to set up my first ESP32 NFC tag reader in ESPHome but not getting too far, can I get some help please
I have the ESP32 connected to the PN532 over I2C, the dip switches are set as seen on the web; 1 on, 2off, connected SDA to GPIO21 and SCL to GPIO22 on the ESP32
I then created a new device in ESPHome on Home Assistant, added the PN532 NFC component and flashed the device.
The new device was detected by ESP Home integration so I added it.
Thats as far as I have got, I can’t see any entities so I must have missed something. On the ESP environment monitors I made I had to add some code from the ESP device library and it worked, however I can’t see any code block on the PN532 only snippets which does not make sense to me I’m afraid.
Is there soemthing I need to add to make this work??
I think NFC reader is probably not best way to get used to esphome. You could configure for example uptime sensor and gpio switch for onboard LED to start with. When you are comfortable with esphome, logs and code uploading, add your reader.
This is the code currently running, its still not right as i have given the tag a name as well as the same name being used as the ID but in settings-tags it shows either the name or a long UID code.
I think I have burnt chatgpt out on this one, I thought it would be easier really.
Any thoughts here?
esphome:
friendly_name: ESP_NFC
esp32:
variant: esp32
framework:
type: esp-idf
logger:
api:
encryption:
key: "xxxxxxx"
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "ESP_NFC Fallback Hotspot"
password: "xxxxxxxxx"
captive_portal:
# ONBOARD LED
output:
- platform: gpio
pin: GPIO2
# SPI BUS
spi:
clk_pin: 18
miso_pin: 19
mosi_pin: 23
# PN532 - SPI
pn532_spi:
cs_pin: 5
spi_id: spi_1
update_interval: 1s
on_tag:
then:
# HOME ASSISTANT TAG
# Only the NDEF Home Assistant tag ID is used.
# The physical PN532 UID is NOT used.
- homeassistant.tag_scanned: !lambda |-
if (!tag.has_ndef_message()) {
return "";
auto message = tag.get_ndef_message();
auto records = message->get_records();
const std::string prefix =
"https://www.home-assistant.io/tag/";
for (auto &record : records) {
std::string payload = record->get_payload();
size_t pos = payload.find(prefix);
if (pos != std::string::npos) {
return payload.substr(pos + prefix.length());
return "";
# DISPLAY TAG ID
- lambda: |-
ESP_LOGW("nfc", "Tag has no NDEF message - ignored");
return;
std::string tag_id =
ESP_LOGI("nfc", "HA TAG: %s", tag_id.c_str());
id(nfc_tag_id).publish_state(tag_id);
return;
ESP_LOGW(
"nfc",
"No Home Assistant tag URL found - ignored"
# TAG SCANNED INDICATOR
- binary_sensor.template.publish:
state: ON
# FLASH ONBOARD LED
- output.turn_on: onboard_led
- delay: 200ms
- output.turn_off: onboard_led
# RESET SCANNED INDICATOR
- delay: 300ms
state: OFF
# TAG ID SENSOR
text_sensor:
name: "NFC Tag ID"
icon: "mdi:nfc"
# TAG SCANNED
binary_sensor:
name: "NFC Tag Scanned"
icon: "mdi:nfc"
Purely for education (mine) if the ID of a phone and it seems my fitbit device as well changes on every scan, how is it used in the outside world for any useful purpose?
Would be pretty cool to unlock and lock using the fitbit but i cant see a way it can be used with a rolling ID code???
LOL, for fun I threw the problem at CGPT and we had some fun down the rabbit hole.
We got as far as CGPT compiling a custom low-level firmware set for me to install that would examine the PN532 responses in far more depth than usual looking for a common denominator that would allow me to use the phone and fitbit as an idenitifer which could be converted into a usable Tag ID
I stopped at that point as I didn’t fancy installing stuff that I knew nothing about from a source such as CGPT, but it was interesting.
I can also suggest not turning on very_verbose logging for the ESP as well, it’s an active little thing
