Help with frigate connecting to double take
hey all i have recently set up double take and am having issues connecting with frigate although i have all the information correct it is constantly stuck i a loop of trying to connect?
at a minimum you should provide your config and logs
ah of course here is my log
24-01-31 15:07:12 error: Error: frigate status error: socket hang up
    at Object.module.exports.checks (/double-take/api/src/util/frigate.util.js:79:11)
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async module.exports.start (/double-take/api/src/controllers/recognize.controller.js:85:21)
24-01-31 15:07:23 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:08:16 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:08:26 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:08:31 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:08:36 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:20 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:26 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:31 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:32 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:45 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:51 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:09:56 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:10:06 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:10:56 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:11:07 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:11:12 error: Error: frigate status error: socket hang up
24-01-31 15:12:09 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:13:09 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:13:40 info: processing doorbell: 1a33acd8-0112-439f-87f0-938777d98c38
24-01-31 15:13:40 info: done processing doorbell: 1a33acd8-0112-439f-87f0-938777d98c38 in 0.16 sec
24-01-31 15:13:40 info: {
  duration: 0.16,
  timestamp: '2024-01-31T15:13:40.586Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  counts: { person: 0, match: 0, miss: 0, unknown: 0 },
  matches: [],
  misses: [],
  unknowns: []
24-01-31 15:40:01 info: processing doorbell: 9a0ea73a-038b-474b-ac6c-4f24f86ff411
24-01-31 15:40:01 info: done processing doorbell: 9a0ea73a-038b-474b-ac6c-4f24f86ff411 in 0.2 sec
24-01-31 15:40:01 info: {
  duration: 0.2,
  timestamp: '2024-01-31T15:40:01.932Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 15:40:06 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 15:40:07 info: processing doorbell: 6fb6e870-1b0d-452e-9233-93a622df0f2d
24-01-31 15:40:07 info: done processing doorbell: 6fb6e870-1b0d-452e-9233-93a622df0f2d in 0.24 sec
24-01-31 15:40:07 info: {
  duration: 0.24,
  timestamp: '2024-01-31T15:40:07.652Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 15:40:11 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:12:10 error: Error: socket hang up
    at connResetException (node:internal/errors:705:14)
    at Socket.socketOnEnd (node:_http_client:518:23)
    at Socket.emit (node:events:525:35)
    at endReadableNT (node:internal/streams/readable:1358:12)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
24-01-31 16:13:00 info: purged 1 file(s)
24-01-31 16:13:35 info: processing doorbell: 360a3a81-efd1-4dc0-87d6-a3df5258ea11
24-01-31 16:13:35 info: done processing doorbell: 360a3a81-efd1-4dc0-87d6-a3df5258ea11 in 0.22 sec
24-01-31 16:13:35 info: {
  duration: 0.22,
  timestamp: '2024-01-31T16:13:35.851Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:13:40 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:16:33 info: processing doorbell: 9aba4409-bc13-495a-b143-91b793da58c5
24-01-31 16:16:33 info: done processing doorbell: 9aba4409-bc13-495a-b143-91b793da58c5 in 0.22 sec
24-01-31 16:16:33 info: {
  duration: 0.22,
  timestamp: '2024-01-31T16:16:33.532Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:16:38 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:16:38 info: processing doorbell: 412354b4-647c-455a-a18f-0e6f445878df
24-01-31 16:16:39 info: done processing doorbell: 412354b4-647c-455a-a18f-0e6f445878df in 0.18 sec
24-01-31 16:16:39 info: {
  duration: 0.18,
  timestamp: '2024-01-31T16:16:39.183Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:16:43 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:19:18 error: Error: socket hang up
24-01-31 16:19:19 error: Error: socket hang up
24-01-31 16:20:29 info: processing doorbell: 64c93422-2af9-49f5-897a-9b3098bb2cb1
24-01-31 16:20:30 info: done processing doorbell: 64c93422-2af9-49f5-897a-9b3098bb2cb1 in 0.18 sec
24-01-31 16:20:30 info: {
  duration: 0.18,
  timestamp: '2024-01-31T16:20:30.003Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:20:34 info: processing front_door: 25ac0484-a18a-46ba-a4bc-ec27652503d1
24-01-31 16:20:34 info: done processing front_door: 25ac0484-a18a-46ba-a4bc-ec27652503d1 in 0.24 sec
24-01-31 16:20:34 info: {
  duration: 0.24,
  timestamp: '2024-01-31T16:20:34.346Z',
  attempts: 1,
  camera: 'front_door',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:20:34 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:20:39 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:20:44 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:20:45 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:20:48 info: processing doorbell: e78fefef-67eb-473e-be0b-c51b9a12dd01
24-01-31 16:20:48 info: done processing doorbell: e78fefef-67eb-473e-be0b-c51b9a12dd01 in 0.21 sec
24-01-31 16:20:48 info: {
  duration: 0.21,
  timestamp: '2024-01-31T16:20:48.398Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:20:49 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:20:50 info: processing front_door: d1f5a5e4-da0a-4141-821f-ca8ac0e46b16
24-01-31 16:20:50 info: done processing front_door: d1f5a5e4-da0a-4141-821f-ca8ac0e46b16 in 0.21 sec
24-01-31 16:20:50 info: {
  duration: 0.21,
  timestamp: '2024-01-31T16:20:50.463Z',
  attempts: 1,
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:21:09 info: Double Take v1.13.1-8e2728d
24-01-31 16:21:11 info: MQTT: connected
24-01-31 16:21:11 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:21:48 error: Error: socket hang up
24-01-31 16:31:11 info: processing doorbell: 2b516eb1-d440-450f-b36a-f377c5aa0517
24-01-31 16:31:11 info: done processing doorbell: 2b516eb1-d440-450f-b36a-f377c5aa0517 in 0.34 sec
24-01-31 16:31:11 info: {
  duration: 0.34,
  timestamp: '2024-01-31T16:31:11.942Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  counts: { person: 1, match: 1, miss: 0, unknown: 0 },
  matches: [
      confidence: 96.89,
      match: true,
      box: [Object],
      type: 'mqtt',
      duration: 0.32,
      detector: 'compreface',
      filename: 'd1f89581-be58-4609-8a60-4ca2836ac8ef.jpg'
  misses: [],
  unknowns: []
24-01-31 16:31:13 info: processing front_door: 5e504f5d-f151-4981-aa64-0e8d9587c057
24-01-31 16:31:13 info: done processing front_door: 5e504f5d-f151-4981-aa64-0e8d9587c057 in 0.24 sec
24-01-31 16:31:13 info: {
  duration: 0.24,
  timestamp: '2024-01-31T16:31:13.424Z',
  attempts: 1,
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:31:16 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:31:18 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:31:21 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:31:22 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:31:23 info: processing doorbell: e6a62b21-128b-47f1-a773-7dce3af96536
24-01-31 16:31:24 info: done processing doorbell: e6a62b21-128b-47f1-a773-7dce3af96536 in 0.19 sec
24-01-31 16:31:24 info: {
  duration: 0.19,
  timestamp: '2024-01-31T16:31:24.066Z',
  attempts: 1,
  camera: 'doorbell',
  zones: [],
  matches: [],
  misses: [],
  unknowns: []
24-01-31 16:31:24 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:31:24 info: processing front_door: 49bb436c-3a90-49c4-b068-d370f21c4dc2
24-01-31 16:31:25 info: done processing front_door: 49bb436c-3a90-49c4-b068-d370f21c4dc2 in 0.31 sec
24-01-31 16:31:25 info: {
  duration: 0.31,
  timestamp: '2024-01-31T16:31:25.287Z',
  attempts: 1,
  zones: [],
  matches: [
      confidence: 95.25,
      match: true,
      box: [Object],
      type: 'mqtt',
      duration: 0.3,
      filename: '6bbf4284-441f-4e8d-bbe7-e4618e3d22e4.jpg'
  misses: [],
  unknowns: []
24-01-31 16:31:26 error: Error: frigate status error: timeout of 5000ms exceeded
24-01-31 16:33:39 info: craig: queuing 1 file(s) for training
24-01-31 16:33:39 info: craig: training complete in 1.26 sec
24-01-31 16:43:52 info: Double Take v1.13.1-8e2728d
24-01-31 16:43:53 info: MQTT: connected
24-01-31 16:43:53 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:44:14 info: Double Take v1.13.1-8e2728d
24-01-31 16:44:15 info: MQTT: connected
24-01-31 16:44:15 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:45:35 info: Double Take v1.13.1-8e2728d
24-01-31 16:45:37 info: MQTT: connected
24-01-31 16:45:37 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:45:50 info: Double Take v1.13.1-8e2728d
24-01-31 16:45:51 info: MQTT: connected
24-01-31 16:45:51 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:46:13 info: Double Take v1.13.1-8e2728d
24-01-31 16:46:15 info: MQTT: connected
24-01-31 16:46:15 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:46:41 info: Double Take v1.13.1-8e2728d
24-01-31 16:46:42 info: MQTT: connected
24-01-31 16:46:42 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:46:57 info: Double Take v1.13.1-8e2728d
24-01-31 16:46:58 info: MQTT: connected
24-01-31 16:46:58 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:47:26 info: Double Take v1.13.1-8e2728d
24-01-31 16:47:27 info: MQTT: connected
24-01-31 16:47:27 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:48:02 info: Double Take v1.13.1-8e2728d
24-01-31 16:48:03 info: MQTT: connected
24-01-31 16:48:03 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:48:17 info: Double Take v1.13.1-8e2728d
24-01-31 16:48:18 info: MQTT: connected
24-01-31 16:48:18 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:48:51 info: Double Take v1.13.1-8e2728d
24-01-31 16:48:52 info: MQTT: connected
24-01-31 16:48:52 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:49:25 info: Double Take v1.13.1-8e2728d
24-01-31 16:49:27 info: MQTT: connected
24-01-31 16:49:27 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:50:23 info: Double Take v1.13.1-8e2728d
24-01-31 16:50:24 info: MQTT: connected
24-01-31 16:50:24 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:50:40 info: Double Take v1.13.1-8e2728d
24-01-31 16:50:41 info: MQTT: connected
24-01-31 16:50:41 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:11 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:13 info: MQTT: connected
24-01-31 16:58:13 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:24 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:25 info: MQTT: connected
24-01-31 16:58:25 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:27 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:28 info: MQTT: connected
24-01-31 16:58:28 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:29 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:30 info: MQTT: connected
24-01-31 16:58:30 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:31 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:32 info: MQTT: connected
24-01-31 16:58:32 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:33 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:34 info: MQTT: connected
24-01-31 16:58:35 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
24-01-31 16:58:36 info: Double Take v1.13.1-8e2728d
24-01-31 16:58:37 info: MQTT: connected
24-01-31 16:58:37 info: MQTT: subscribed to frigate/events, frigate/+/person/snapshot
