Hi all,
I have a camera in my garage that should only trigger motion or detect a person outside the door boundaries. (basically in the garage and not in the corridor)
I have created first a mask and I noticed that HA still triggers as motion and detection whenever somebody passes in the corridor (does not enter the garage), then I have created on top of the mask a zone, to include all garage with the exception of the door, however the problem still remains.
I am not sure what I am doing wrong, can I have some help if possible.
Frigate config for that camera:
Garage:
ffmpeg:
inputs:
#LOW RESOLUTION
- path: rtsp://127.0.0.1:8554/Garage_Sub
input_args: preset-rtsp-restream
roles:
- detect
#HIGH RESOLUTION
- path: rtsp://127.0.0.1:8554/Garage_Main
roles:
- record
live:
stream_name: Garage_Sub
detect:
width: 896
height: 512
fps: 5
snapshots:
enabled: true
record:
enabled: true
retain:
days: 7
mode: motion #all = 24/7, motion = when there is motion, active_objects = verified detected objects
events:
retain:
default: 14
mode: active_objects #all = 24/7, motion = when there is motion, active_objects = verified detected objects
required_zones:
- garage_all_except_corridor
motion:
threshold: 20
lightning_threshold: 0.8
contour_area: 10
frame_alpha: 0.01
mqtt_off_delay: 10
improve_contrast: True
mask:
- 428,0,778,0,741,338,612,293,628,338,418,279
zones:
garage_all_except_corridor:
coordinates: 0,0,311,0,368,266,745,367,764,0,896,0,896,512,426,512,424,406,0,412
objects:
- person
filters:
person:
min_area: 7500
max_area: 85000
min_score: 0.7
threshold: 0.75
objects:
track:
- person
filters:
person:
min_area: 7500
max_area: 85000
min_score: 0.7
threshold: 0.75
ui:
order: 6
dashboard: true
Home assistant detection
Frigate zone
Frigate motion mask
