Hey guys! Can you please help with a Frigate install.
I’m trying to install a standalone frigate install on Debian 12, in docker.
I have tried so many methods, Docker, Docker compose and all result with the same issue,
The container comes up, but as soon as I browse to the web UI, the container just restarts and doesnt come back up.
Here are the logs
root@debian2:/home/frigate# docker compose up
[+] Running 2/2
✔ Network frigate_default Created 0.1s
✔ Container frigate Created 0.0s
Attaching to frigate
frigate | s6-rc: info: service s6rc-fdholder: starting
frigate | s6-rc: info: service s6rc-oneshot-runner: starting
frigate | s6-rc: info: service s6rc-oneshot-runner successfully started
frigate | s6-rc: info: service fix-attrs: starting
frigate | s6-rc: info: service s6rc-fdholder successfully started
frigate | s6-rc: info: service fix-attrs successfully started
frigate | s6-rc: info: service legacy-cont-init: starting
frigate | s6-rc: info: service legacy-cont-init successfully started
frigate | s6-rc: info: service log-prepare: starting
frigate | s6-rc: info: service log-prepare successfully started
frigate | s6-rc: info: service nginx-log: starting
frigate | s6-rc: info: service go2rtc-log: starting
frigate | s6-rc: info: service frigate-log: starting
frigate | s6-rc: info: service nginx-log successfully started
frigate | s6-rc: info: service go2rtc-log successfully started
frigate | s6-rc: info: service go2rtc: starting
frigate | s6-rc: info: service frigate-log successfully started
frigate | s6-rc: info: service go2rtc successfully started
frigate | s6-rc: info: service go2rtc-healthcheck: starting
frigate | s6-rc: info: service frigate: starting
frigate | s6-rc: info: service go2rtc-healthcheck successfully started
frigate | s6-rc: info: service frigate successfully started
frigate | s6-rc: info: service nginx: starting
frigate | 2023-11-25 03:27:57.754108491 [INFO] Preparing go2rtc config...
frigate | s6-rc: info: service nginx successfully started
frigate | s6-rc: info: service legacy-services: starting
frigate | 2023-11-25 03:27:57.757563742 [INFO] Starting Frigate...
frigate | 2023-11-25 03:27:57.760960651 [INFO] Starting NGINX...
frigate | s6-rc: info: service legacy-services successfully started
frigate | Traceback (most recent call last):
frigate | File "/usr/local/go2rtc/create_config.py", line 23, in <module>
frigate | with open(config_file) as f:
frigate | IsADirectoryError: [Errno 21] Is a directory: '/config/config.yml'
frigate | 2023-11-25 03:27:57.990867705 [INFO] The go2rtc service exited with code 1 (by signal 0)
frigate | 2023-11-25 03:27:58.706603868 ************************************** ***********************
frigate | 2023-11-25 03:27:58.706607669 ************************************** ***********************
frigate | 2023-11-25 03:27:58.706609591 *** Your config file is not valid! ***
frigate | 2023-11-25 03:27:58.706611362 *** Please check the docs at ***
frigate | 2023-11-25 03:27:58.706612728 *** https://docs.frigate.video/conf iguration/index ***
frigate | 2023-11-25 03:27:58.706614383 ************************************** ***********************
frigate | 2023-11-25 03:27:58.706615588 ************************************** ***********************
frigate | 2023-11-25 03:27:58.706628544 *** Config Validation Errors ***
frigate | 2023-11-25 03:27:58.706629903 ************************************** ***********************
frigate | 2023-11-25 03:27:58.706904240 [Errno 21] Is a directory: '/config/co nfig.yml'
frigate | 2023-11-25 03:27:58.707703485 Traceback (most recent call last):
frigate | 2023-11-25 03:27:58.707705618 File "/opt/frigate/frigate/app.py", line 351, in start
frigate | 2023-11-25 03:27:58.707706873 self.init_config()
frigate | 2023-11-25 03:27:58.707708125 File "/opt/frigate/frigate/app.py", line 80, in init_config
frigate | 2023-11-25 03:27:58.707709324 user_config = FrigateConfig.parse_ file(config_file)
frigate | 2023-11-25 03:27:58.707710523 File "/opt/frigate/frigate/config.py ", line 1070, in parse_file
frigate | 2023-11-25 03:27:58.707711542 with open(config_file) as f:
frigate | 2023-11-25 03:27:58.707712683 IsADirectoryError: [Errno 21] Is a dir ectory: '/config/config.yml'
frigate | 2023-11-25 03:27:58.707713590
frigate | 2023-11-25 03:27:58.707714745 ************************************** ***********************
frigate | 2023-11-25 03:27:58.707715838 *** End Config Validation Errors ***
frigate | 2023-11-25 03:27:58.707717948 ************************************** ***********************
frigate | 2023-11-25 03:27:58.707918697 [2023-11-25 03:27:58] frigate.app INFO : Starting Frigate (0.12.1-367d724)
frigate | 2023-11-25 03:27:59.003093117 [INFO] Preparing go2rtc config...
frigate | 2023-11-25 03:27:59.184836783 [INFO] The go2rtc service exited with code 1 (by signal 0)
frigate | 2023-11-25 03:27:59.831225908 [INFO] Service Frigate exited with cod e 1 (by signal 0)
frigate | s6-rc: info: service legacy-services: stopping
frigate | s6-rc: info: service legacy-services successfully stopped
frigate | s6-rc: info: service nginx: stopping
frigate | s6-rc: info: service go2rtc-healthcheck: stopping
frigate | 2023-11-25 03:27:59.841714710 [INFO] The go2rtc-healthcheck service exited with code 256 (by signal 15)
frigate | s6-rc: info: service go2rtc-healthcheck successfully stopped
frigate | 2023-11-25 03:27:59.965157887 [INFO] Service NGINX exited with code 0 (by signal 0)
frigate | s6-rc: info: service nginx successfully stopped
frigate | s6-rc: info: service nginx-log: stopping
frigate | s6-rc: info: service frigate: stopping
frigate | s6-rc: info: service frigate successfully stopped
frigate | s6-rc: info: service go2rtc: stopping
frigate | s6-rc: info: service frigate-log: stopping
frigate | s6-rc: info: service nginx-log successfully stopped
frigate | s6-rc: info: service go2rtc successfully stopped
frigate | s6-rc: info: service go2rtc-log: stopping
frigate | s6-rc: info: service frigate-log successfully stopped
frigate | s6-rc: info: service go2rtc-log successfully stopped
frigate | s6-rc: info: service log-prepare: stopping
frigate | s6-rc: info: service s6rc-fdholder: stopping
frigate | s6-rc: info: service log-prepare successfully stopped
frigate | s6-rc: info: service legacy-cont-init: stopping
frigate | s6-rc: info: service s6rc-fdholder successfully stopped
frigate | s6-rc: info: service legacy-cont-init successfully stopped
frigate | s6-rc: info: service fix-attrs: stopping
frigate | s6-rc: info: service fix-attrs successfully stopped
frigate | s6-rc: info: service s6rc-oneshot-runner: stopping
frigate | s6-rc: info: service s6rc-oneshot-runner successfully stopped
frigate exited with code 0
and my docker file.
version: "3.9"
services:
frigate:
container_name: frigate
privileged: true # this may not be necessary for all setups
restart: unless-stopped
image: ghcr.io/blakeblackshear/frigate:stable
shm_size: "64mb" # update for your cameras based on calculation above
# devices:
# - /dev/bus/usb:/dev/bus/usb # passes the USB Coral, needs to be modified for other versions
# - /dev/apex_0:/dev/apex_0 # passes a PCIe Coral, follow driver instructions here https://coral.ai/docs/m2/get>
# - /dev/dri/renderD128 # for intel hwaccel, needs to be updated for your hardware
volumes:
- /etc/localtime:/etc/localtime:ro
- /path/to/your/config.yml:/config/config.yml
- /path/to/your/storage:/media/frigate
- type: tmpfs # Optional: 1GB of memory, reduces SSD/SD Card wear
target: /tmp/cache
tmpfs:
ports:
- "5000:5000"
- "8554:8554" # RTSP feeds
- "8555:8555/tcp" # WebRTC over tcp
- "8555:8555/udp" # WebRTC over udp
environment:
FRIGATE_RTSP_PASSWORD: "password"
I think I obviously need to change the /path/to/your/* to a valid path but not sure what.
