Help with Fully Kiosk on Amazon Tablet
Hi.
I’m trying to integrate my Amazon Fire Tablet with Home Assistant, but after spending hours on this I cannot seem to be able to see the sensor on HA
I’m running Hassio on a virtual Ubuntu server and is working well
I installed Fully Kiosk on the tablet and it looks good. However HA cannot see the sensor, find below details of my configuration:
sensors.yaml:
  • platform: rest
    json_attributes:
    • batteryLevel
    • kioskMode
    • screenBrightness
    • motionDetectorState
    • maintenanceMode
    • appFreeMemory
    • appUsedMemory
    • totalFreeMemory
    • totalUsedMemory
    • hostname4
    • ip4
    • mac
    • locationLatitude
    • locationLongitude
    • locationAltitude
    • startUrl
    • currentPage
      resource: !secret foo_rest
      value_template: ‘{{ value_json.isScreenOn }}’
secrets.yaml:
foo_rest: http://192.168.1.26:2323/?cmd=deviceInfo&type=json&password=mypassword
I have tried the url on a browser and I get all those details
I’m not sure if the problem is that I’m using a fire tablet , or something else
Your help will be appreciated
This is one of my REST and Template configuration for FullyKiosk (Licensed) on Fire7 Tablet.
 - platform: rest
   json_attributes:
    - androidSdk
    - androidVersion
    - appFreeMemory
    - appUsedMemory
    - appVersionCode
    - appVersionName
    - batteryLevel
    - currentFragment
    - currentPage
    - currentTabIndex
    - deviceID
    - deviceManufacturer
    - deviceModel
    - deviceName
    - displayHeightPixels
    - displayWidthPixels
    - foregroundApp
    - hostname4
    - hostname6
    - ip4
    - ip6
    - isDeviceAdmin
    - isDeviceOwner
    - isLicensed
    - isScreenOn
    - keyguardLocked
    - kioskLocked
    - kioskMode
    - lastAppStart
    - mac
    - maintenanceMode
    - motionDetectorState
    - plugged
    - screenBrightness
    - screenOrientation
    - ssid
    - startUrl
    - totalFreeMemory
    - totalUsedMemory
    - webviewUa
    - wifiSignalLevel
   resource: http://dash-entrance:2323/?cmd=deviceInfo&type=json&password=password
   timeout: 60
   value_template: >-
     {%- if value_json.isScreenOn -%}
       On
     {%- else -%}
       Off
     {%- endif %}
   sensors:
     entrance_dashboard_battery:
       friendly_name: "Entrance Dashboard Battery"
       device_class: battery
       unit_of_measurement: '%'
       entity_id: sensor.entrance_dashboard
       value_template: "{{ states.sensor.entrance_dashboard.attributes.batteryLevel }}"
Have you purchased a license? It’s worth it! I am under the impression that to use the REST API it has to be licensed.
Any error in the logs? Can you ping the tablet from where your HA instances is running?
Tony
Thanks for your reply
I bought the full license, as i thought that could be the problem
I will try your configuration.
Did you set a password on the fully kiosk app gor the home assistant page? I was wondering if that could be the problem.
I set the logging to debug, but could not see anything obvious.
I don’t think the problem could be the network, as there are on the same subnet and nothing prevents the communication
Regards
Javier
I have actually tested the API from within linux on the Home assistant box, and it works, for example:
curl --request POST ‘http://192.168.1.26:2323/?cmd=deviceInfo&type=json&password=mypassword
curl --request POST ‘http://192.168.1.26:2323/?cmd=triggerMotion&password=mypassword
So it seems like HA, for some reason simply is ignoring the information I put on the sensors.yaml file - although I checked and the syntax is 100% correct.
Maybe I’m missing something?
Thanks again
Do you see the sensor you have defined in the Configuration -> Entities list? If not, make sure your sensors.yaml file is being included. Check your configuration.yaml to ensure you have the appropriate include line for sensors.yaml.
I’ve been working on a custom component to control Fully Kiosk Browser in HA. It can be added as a custom repository in HACS. Currently supports a handful of sensors, a light entity to turn the screen on/off and control brightness, and switches to control the screensaver, kiosk lock, and maintenance mode.
Hi Charles
Thanks gor your tip
I will try tomorrow ss soon as i have a bit if free time
I will let you know how it goes
Javier
Tony
You hit the nail on the head: there is no include sensors.yaml in configuration.yaml
It seems the sensors.yaml have the code duplicated on the sensors.yaml, which is why it works with the current sensors!
I will give it a try tomorrow
Thanks again
Javier
