I created a function for multiple thermostats to receive alexa commands, and send a service call for thermostat mode and/or temperature, to a service call node.
My issue is that the service call node is giving me an API error saying it’s missing the “service” portion in the payload…cant figure out what is wrong.
I do not know if that method is actually possible, but try qtleast to make just set service as set_hvac_mode, since climate is already stated in the domain. It’s just a guess though.
You can leave the call service node completely blank and send everything in the message. I can pass domainservice and entity but I haven’t figured out the format for data. The example linked doesn’t work for me.
