I am looking for a way to get the time one hour before sunset. My goal is to see if the the current time is between sunset - 1 hr and sunset. For the sake of readability, I want to avoid templating as much as possible. Simply put, I want it to look something like this, if possible:
- condition: time
after: sensor.sun_next_setting - 1hr
before: sensor.sun_next_dusk
Is there a way to create a helper for example to give me the time for that day sunset - 1hr?
Should I create this as Helpers > Template > Sensor? I get a value, but in my automation I can’t select the helper in my condition between two different times.
For future reference, the inclusion of device_class: timestamp is important because it identifies it as being a Timestamp sensor. Without it, it’s a regular sensor and even if it has a proper date and time value, it can’t be used in a Time Condition (as you have already discovered).
device_class is an option of a Template Sensor’s YAML configuration (it’s never part of its template which is used in the state option).
If you create the suggested Template Sensor via the UI then only a few of a Template Sensor’s many options are available in the form. Fortunately, device_class is one of them and it appears as the Apparatklasse field in your screenshot. You chose timestamp (tijdstup) which is effectively the same as device_class: timestamp if you had defined the Template Sensor using YAML.
