Hi all, I’m based in the UK and trying to use the showmyhomework website along with the google calendar component so that I can announce when my son’s homework is due/what subject etc.
Problem is that the description attribute isn’t laid out in a very helpful way, and the message attribute has an annoying class name that doesn’t read out very well over a google home!
Is there anyway of extracting the information I may be interested in and excluding the other bits? Here is what is showing in my states attribute under calendar.smhw.calendar:
message: Karl *redacted* 08C2L/La German Homework
all_day: false
offset_reached: false
start_time: 2018-09-19 10:00:00
end_time: 2018-09-19 10:00:00
description: German
Class Name: 08C2L/La
Homework Title: Year 8 German homework
Set By: Mrs D. Rae
Set On: Wed 12th Sep
Due On: Wed 19th Sep
View on *redacted* School's Homework Calendar
https://www.showmyhomework.co.uk/redacted
friendly_name: SMHW Calendar
I’d probably want to use the homework title and due on date, and combine with a days until sensor which I am already able to set up.
This is an example of an automation that notifies when his homework has to be done within 16 hours:
Dates are hard to calculate, so its easier when converted to timestamps(Unix time, the number of seconds since 00:00:00 UTC on January 1, 1970)
- alias: 'Work Notifications'
platform: time
minutes: /30
seconds: 00
condition:
condition: and
conditions:
- condition: template
value_template: '{% set start_date = as_timestamp(states.calendar.annoying_calendar_name.attributes.start_time) %}
{% set date = as_timestamp(now()) %}
{%set diff = start_date -date %}
{{ diff>57600 }}' ### 16 hours in seconds, so should warn you at 6PM
service_template: notify.telegram
title: "Homework to do!"
message: '{{ states.calendar.annoying_calendar_name.attributes.description }}'
I run something similar to tell me to go to bed if I have a job before 8AM
You can also easily use the same template code to create template sensors
Thanks for this. I’m already using a different automation for another calendar that tells me from 3 days before when an event is due. The issue I have is the description has a lot of information that I don’t need. Is there a way to filter out the stuff I don’t need? The information is provided by ical into my google calendar.
Have you thought of creating a template sensor that would extract what you need?
Assuming the format is the same for all classes
Class description (German): value_template: '{{states.calendar.calendar_name.attributes.description.split("Class Name: ")[0] | trim}}'
Class name(08C2L/La): value_template: '{{states.calendar.calendar_name.attributes.description.split("Class Name: ")[1].split("Homework Title: ")[0] | trim}}'
