Help with ha-bridge API HA setup
I have HA and ha-bridge on a pi3. First time at all this and after a couple days finally got my two switches working in HA thanks to searching through this forum and BRUH. I have done some searches and can’t find a solution. There may be one staring me in the face but I cannot see it. I have ha-bridge running and going good. Added my harmony hub to it and can control it from the web interface at local:8080. I am having a problem getting the light to work calling it through home assistant and can’t find much out there except the same posts that don’t seem to address my problem. I am trying to add a device I control in Home Assistant and can run a curl on my pi and switch it on and off with a POST. I use the same entity id and http address but it doesn’t control it from the web. My echo can see the light and tries to turn it on but says it is not responding. I have changed every thing I have found and then some but can’t seem to get it to work. These are GE zwave switches. Please take a look at my setup attached and let me know what I may be missing. ha-bridge is not making any logs for it either. it will create a log for the harmony stuff.
Reboot the pi did the trick. tried a restart of ha-bridge and HA but again I am new at this and obviously messed that up too. :smile: Thanks everyone! great community here. Will leave the above up just in case it comes in handy for someone.
