Good Day
I have a problem implementing python external libraries with appdaemon. I have the following, I am trying to implement a microsoft sql express system with my app daemon system, so that when I receive the last data of a column that I have, the problem I have is that when trying to call the obdc or pymssql library and freetds ( this is not imported but if I need it for the configuration of the communication), it tells me that the module does not exist and ignores me the automation.
I have my appdaemon.yaml as follows, I was checking and I saw that there was a way to export python packages to what I am new and I don’t know how to:
Thank you very much in advance
and my status shows this:
Aug 24 18:27:01 hassbian appdaemon[1403]: File "<frozen importlib._bootstrap_external>", line 728, in exec_module
Aug 24 18:27:01 hassbian appdaemon[1403]: File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
[u]***Aug 24 18:27:01 hassbian appdaemon[1403]: File "/srv/apps/Puerta.py", line 1, in <module>***[/u]
[u]***Aug 24 18:27:01 hassbian appdaemon[1403]: import pymssql***[/u]
[u]***Aug 24 18:27:01 hassbian appdaemon[1403]: ModuleNotFoundError: No module named 'pymssql'***[/u]
Aug 24 18:27:01 hassbian appdaemon[1403]: 2019-08-24 18:27:01.917759 WARNING AppDaemon: ------------------------------------------------------------
Aug 24 18:27:01 hassbian appdaemon[1403]: 2019-08-24 18:27:01.918108 WARNING AppDaemon: Removing associated apps:
Aug 24 18:27:01 hassbian appdaemon[1403]: 2019-08-24 18:27:01.918510 WARNING AppDaemon: abrir_puerta
Aug 24 18:27:01 hassbian appdaemon[1403]: 2019-08-24 18:27:01.918971 INFO AppDaemon: Initializing app hello_world using class HelloWorld from module Hello
Aug 24 18:27:01 hassbian appdaemon[1403]: 2019-08-24 18:27:01.971424 INFO AppDaemon: App initialization complete```
