Hello
i can’t update HA Rpi4 from HassOS 3.13 to HassOS 4.9 it give this:
can you help me ?
thank you
Hello
can you help me ?
thank you
Enough storage available?
Yes there more than enough storage available
I believe the 4.x series has been withdrawn for raspberry pis as it was buggy. Apparently 4.10 will fix it.
I upgraded today, and now it won’t start up. Rpi 4. I saw where someone had this issue and edited the config.txt to be able to start back up and then rolled back. I don’t know where to find the config.txt
So do i try upgrade or not what you recommend?
No you should not. Like I said 4.9 has been withdrawn for raspberry pi.
Ok thank you all for your help
