Hi All,
I’ve trying many different approaches but have had no luck. I have replicated the ifan02 from the cookbook in the way that suits me (d1 mini and a 4-way relay board)and it works fantastically, now I’m trying to do the same but instead of running directly off the d1 mini I am trying to use an MCP23017 which means using the i2c in the custom component. By doing this I hope to control many fans from just 1 d1 mini.
Is anyone able to help me?
The code I’m trying at the moment looks like this:
esphome:
platform: ESP8266
board: d1_mini
includes:
- ifan02test.h
wifi:
ssid: "****"
password: "****"
ap:
ssid: "****"
password: "****"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
sda: D5
scl: D6
scan: True
mcp23017:
- id: 'mcp23017_hub'
address: 0x20
output:
- platform: custom
type: float
outputs:
lambda: |-
auto test_fan = new FanOutput();
App.register_component(test_fan);
return {test_fan};
fan:
- platform: speed
output: fanoutput
and the custom_component.h (ifan02test.h) file:
#include "esphome.h"
using namespace esphome;
class FanOutput : public Component, public FloatOutput {
public:
void write_state(float state) override {
if (state < 0.3) {
// OFF
Wire.beginTransmission(0x20); //address of MCP23017
Wire.write(0x12); // port a
Wire.write(0xFF); // write all pins high
Wire.endTransmission();
} else if (state < 0.6) {
// HIGH speed
Wire.write(0xFB); // write pin 3 low
} else if (state < 0.9) {
// medium speed
Wire.write(0xFD); // write pin 2 low
} else {
// LOW speed
Wire.write(0xFE); // write pin 1 low
everything compiles fine with no errors however nothing happens on the i2c or 4-way relay board.
I have tried something similar with arduino on an arduino uno and managed to get it to work.
