Hello ESPHome Community!
I’m trying to set up an INMP441 I2S microphone with my ESP32-WROVER-KIT to stream audio over MQTT. I’ve followed the ESPHome documentation, but I keep running into issues with the configuration. I’m looking for help with correctly setting up the I2S audio capture and sending the data to my MQTT broker.
Hardware Setup:
- Microphone: INMP441 (I2S microphone)
- ESP32 Board: ESP32-WROVER-KIT
- I2S Pin Connections:
| INMP441 Pin | ESP32 Pin | Description |
| VCC | 3.3V | Power supply (3.3V) |
| GND | GND | Ground |
| SCK | GPIO14 | Serial Clock (SCK) |
| WS | GPIO15 | Word Select (LRCLK) |
| SD | GPIO32 | Serial Data (SD) |
| L/R | GND |
ESP32-WROVER-KIT Pinout:
The ESP32-WROVER-KIT has multiple available pins for I2S functionality, and GPIO14, GPIO15, and GPIO32 are often used for I2S data. These should work well with the INMP441 microphone.
My ESPHome Configuration:
esphome:
platform: ESP32
board: esp32wrover-kit # Board setup for ESP32-WROVER-KIT
wifi:
ssid: "YOUR_SSID"
password: "YOUR_PASSWORD"
logger:
api:
ota:
mqtt:
broker: "YOUR_MQTT_BROKER_IP" # IP of your MQTT broker
username: "YOUR_MQTT_USERNAME"
password: "YOUR_MQTT_PASSWORD"
topic_prefix: "audio_streamer"
# I2S microphone configuration (e.g., INMP441)
i2s_audio:
i2s_id: 0
sck_pin: GPIO14 # Serial Clock (SCK) pin
ws_pin: GPIO15 # Left-Right Clock (LRCLK or WS) pin
sd_pin: GPIO32 # Serial Data (SD) pin
i2s_lrclk_pin: GPIO15 # Explicitly specify the Left-Right Clock (LRCLK) pin
sample_rate: 16000
bits_per_sample: 16
channel_format: I2S_CHANNEL_FMT_ONLY_LEFT # Use mono audio (one channel)
update_interval: 1s # Update the sensor every second (adjust as needed)
- platform: i2s_audio
name: "I2S Microphone"
on_value:
then:
- mqtt.publish:
topic: "audio/data"
payload: !lambda 'return id(microphone_sensor).state;'
api:
services:
- service: play_audio
variables:
audio_data: string
then:
- logger.log: 'Received audio data:'
- logger.log: ' Audio: !audio_data'
Issue:
When I try to compile the configuration, I get the error:
`i2s_lrclk_pin` is a required option for [0]. Did you mean [i2s_lrclk_pin], [i2s_mclk_pin], [i2s_bclk_pin]?
I’ve checked the documentation and found that the i2s_lrclk_pin option should be required, but I’m unsure of how to properly configure it for my INMP441.
Questions:
- Correct Pin Configuration: Am I wiring the INMP441 correctly to the ESP32-WROVER-KIT? Should I use GPIO14, GPIO15, and GPIO32 for the SCK, LRCLK/WS, and SD pins respectively?
- Correct ESPHome Configuration: Is my ESPHome configuration missing any other necessary parameters? Specifically, I’m unsure about the i2s_lrclk_pin setting.
