### The problem
Until recently connecting a Symfonisk controller as a new devic…e on ZHA would give the usual triggers: (press, double press, triple press, rotate left, rotate right). Now a new device is connected and it has no triggers, only identity and power
Previously it would register as this:
"manufacturer": "IKEA of Sweden",
"model": "SYMFONISK Sound Controller",
"class": "zhaquirks.ikea.symfonisk.IkeaSYMFONISK"
Now it registers as:
"class": "zigpy.device.Device"
### What version of Home Assistant Core has the issue?
core-2022.5.0
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
ZHA
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/zha/
### Diagnostics information
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.5.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.9.9",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Stockholm",
"os_name": "Linux",
"os_version": "5.10.103-v8",
"supervisor": "2022.05.0",
"host_os": "Home Assistant OS 7.6",
"docker_version": "20.10.9",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"resrobot": {
"version": "v0.0.12",
"requirements": []
"hacs": {
"version": "1.24.5",
"requirements": [
"aiogithubapi>=21.11.0"
"xiaomi_miot": {
"version": "0.5.5",
"requirements": [
"construct==2.10.56",
"python-miio>=0.5.6",
"micloud>=0.3"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.29.0",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.73",
"zigpy-deconz==0.16.0",
"zigpy==0.45.1",
"zigpy-xbee==0.14.0",
"zigpy-zigate==0.7.4",
"zigpy-znp==0.7.0"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"after_dependencies": [
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 31444,
"name": "IKEA of Sweden SYMFONISK Sound Controller",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4476,
"power_source": "Battery or Unknown",
"lqi": 255,
"rssi": -49,
"last_seen": "2022-05-05T17:51:54",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4476, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0006",
"in_clusters": [
"0x0000",
"0x0001",
"0x0003",
"0x0020",
"0x1000",
"0xfc7c"
"out_clusters": [
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0019",
"0x1000"
"entities": [
"entity_id": "button.ikea_of_sweden_symfonisk_sound_controller_d4a96bfe_identify",
"entity_id": "sensor.ikea_of_sweden_symfonisk_sound_controller_d4a96bfe_power",
"neighbors": [],
"endpoint_names": [
"name": "REMOTE_CONTROL"
"user_given_name": null,
"device_reg_id": "fb845a6f2ac4df0bf6013a8e5c116876",
"area_id": null
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
```txt
by IKEA of Sweden
Connected via Zigbee Coordinator
Firmware: 0x23080631
### Additional information
_No response_
