Hi guys,
I have been playing around with history_stats in the config yaml.
Got some nice cards set up but I know that history_stats is pulling from the local sql db so only had 6/7 days of data.
I have my data now feeding into influxdb also with retention policy much longer.
How can I write a query equivalent to the one below but to pull the same data from influxdb? See blue arrows from my screen shot.
Thanks a lot
- platform: history_stats
name: Downstairs Heating ON 30 days
entity_id: switch.sonoff_1000907bc4
state: 'on'
type: time
end: '{{ now().replace(hour=0, minute=0, second=0) }}'
duration:
days: 30
Maybe the way to go is to use an inlfuxdb script and make it continuous.
Getting familiar with the syntax
from(bucket: "home_assistant/autogen")
|> range(start: -30d)
|> filter(fn: (r) => r._measurement == "state" and r._value == "on" and (r._field == "state"))
|> stateDuration(fn: (r) => r._value == "on", column: "ON", unit: 1s)
ok this is the data I want to show but I created this in flux and created a dashboard showing the single figure.
How do I get this into grafana or show directly on my lovelace card?
|> range(start: -30d)
|> filter(fn: (r) => r._measurement == "state" and r._value == "on")
|> filter(fn: (r) => r.entity_id == "sonoff_1000729132")
|> stateDuration(
fn: (r) => r._value == "on" ,
column: "PoolPump_OnTime",
unit: 1m
|> top(n:1, columns: ["PoolPump_OnTime"])
|> keep(columns: ["PoolPump_OnTime","_time"])
