Trying to add a slider bar to enable a light off timer automation so I can chanmge the time the light is on for before turning off.
Currently this is my automation set to 20 min. I wish to be able to change that 20 min between 1 and 60
- id: timed_ensuite_light
alias: Ensuite Light Timer
- entity_id: light.ensuite_light
for:
minutes: 20
platform: state
to: 'on'
service: light.turn_off
and this is the slider in my config.yaml
input_number:
slider1:
initial: 30
min: 1
max: 60
step: 1
Still learning input number so just left it all defaults but cant figure out what needs to go in the automation to enable the slider.
Have tried different things with the trigger and even with a condition but cant get it.
Any help for be great.
You will be able to use a template with the state trigger’s for:
option starting with 0.96. In fact it’s already in the beta release. See:
home-assistant:dev
← pnbruckner:state-for-template
opened 08:34PM - 02 Jul 19 UTC
Thanks so I just have to wait or go beta
Well people have done this other ways because they had to. But, yes, it will be much easier once you are using 0.96.0b0 or later.
0.96 has included it and it now works a treat.
Have mine set so when set to 0 it disables the automation that it is linked to for its timer so I am able to remove a toggle switch and just replace it with a slider.
code just in case someone else is seeking the same
input_number
ensuite:
name: Ensuite Light Timer
min: 0
max: 60
step: 1
unit_of_measurement: mins
Automation with the slider
for:
minutes: "{{ states('input_number.ensuite') | int }}"
platform: state
to: 'on'
Automations to trigger the above automation on/off with the slider
- id: turn_off_ensuite_timer
alias: Ensuite Timer Off
- entity_id: input_number.ensuite
platform: state
to: '0.0'
- service: automation.turn_off
entity_id: automation.ensuite_light_timer
- id: turn_on_ensuite_timer
alias: Ensuite Timer On
platform: state
- service: automation.turn_on
Glad to hear it!
No real need for the extra automations. You can effectively do the same by adding a condition to the first automation:
for:
platform: state
to: 'on'
condition:
condition: template
value_template: "{{ states('input_number.ensuite') | int > 0 }}"
Had a feeling there was a cleaner way to do it and was going to look into that today so you just saved me the effort. Thanks.
Wondering if you can help with my next input_number problem.
Have a humidity sensor in the bathroom that activates the exhaust fan but I want to be abe to change the humidity trigger point.
Ive tried the following but it does not like it.
input_number.ensuitefanhum is the humidity input_number slider
- id: ensuit_fan_humidity
alias: Exhaust Fan
- entity_id: sensor.test_humidity
platform: numeric_state
above: "{{ states('input_number.ensuitefanhum') | int }}"
condition:
- condition: state
state: 'on'
- entity_id: fan.ensuite_fan
service: fan.turn_on
doing
above: '80'
works for readings above 80 but I would like to use a slider to change this.
I can get it working using a time_pattern but this seems like extra work the system needs to do for a simply task
alias: Exhaust Fan
platform: time_pattern
seconds: '/15'
condition:
- condition: state
state: 'on'
- condition: template
value_template: "{{ states('sensor.test_humidity') | float > states('input_number.ensuitefanhum') | float }}"
AhmadK
(akasma74)
July 31, 2019, 8:23am
11
I think it would be better to create a new topic, just for the sake of clarity and readability
Speaking about time_pattern - I don’t remember and can’t check right now, but my setup reacts to state change of the slider instead of periodic checks, hope it helps.
Was going to create a new topic but it is still a similar issue so thought I could just tag it on.
The issue I have is I can’t get the slider to be used as a trigger to enable any state change reactions.
The time_pattern is my current work around to get it working
AhmadK
(akasma74)
July 31, 2019, 8:28am
13
why? something like this
platform: state
entity_id: input_number.ensuitefanhum
should do the job.
Thanks I will give that a go. Maybe what I was doing was over complicating the formula.
If I understand the question properly, use the following as a trigger
- platform: state
which should cause a trigger any time that input_number
is changed
Damn it! @AhmadK beat me to it
Sorry I think the question has been misunderstood.
I need the trigger to be linked to the humidity sensor and only trigger when the sensor is above the slider value.
The issue is with the above: entry. I will try putting input_number.ensuitefanhum in the above: section once I finish work and get home
The above code looks like it will work only if the slider is changed. Unless I am reading it wrong.
- platform: state
condition:
- service: fan.turn_on
Won’t this only trigger if the slider is changed?(assuming the condition is met)
I want to use the slider to change the point where the trigger activates.
It will trigger to test the condition any time the slider is moved. It will only process the action if the value is above the slider value. In order to have it trigger on the sensor value as well, we need another trigger:
- platform: state
- platform: state
entitiy_id: sensor.test_humidity
condition:
which will then also test the condition whenever the humidity changes
Will that only trigger if the slider is moved?
Want the slider to set the value that the humidity sensor triggers when it’s above the slider value.
(On my phone so it’s a pain in the backside)
