Help with Input Select for Scenes
I’m trying to setup Input Select to select some scenes for some lights. I’ve not done it before, so don’t really know what I’m doing.
Here’s what I have up to now:
input_select:
  living_room_scenes:
    options:
      - Full Brighness
      - Early Evening
      - Late Evening
      - Dim to 50%
    initial: Full Brighness
    icon: mdi:lightbulb-on-outline
scene:
  - name: Full Brighness
    entities:
      input_select.full_brightness:
        option: Full Brighness
      switch.lounge_light:
        state: on
        transition: 2
        brightness: 254
      switch.dining_room_light:
        state: on
        transition: 2
        brightness: 254
  - name: Early Evening
    entities:
      input_select.early_evening:
        option: Early Evening
        state: on
        transition: 2
        brightness: 191
        state: off
        transition: 2
  - name: Late Evening
    entities:
      input_select.late_evening:
        option: Late Evening
        state: off
        transition: 2
        state: on
        transition: 2
        brightness: 25
  - name: Dim to 50
    entities:
      input_select.dim_50:
        option: Dim to 50
        state: on
        transition: 2
        brightness: 127
        state: on
        transition: 2
        brightness: 127
This doesn’t work at the moment. I wasn’t sure if I should also add some ‘automation’ code or not? If so, any help with that code would be appreciated :slight_smile:
Yes you need some automations to actually activate those scenes. Right now all you have is just scenes which never get called.
~Cheers
Yes, so you have your menu, and you have your scenes, and you need to tie them together with an automation for each one just like you’re thinking. Something like this:
 - alias: Full Brightness selected
          platform: state
          entity_id: input_select.living_room_scenes
          to: "Full Brightness"
          service: scene.turn_on
          entity_id: scene.full_brightness
 - alias: Early Evening selected
          platform: state
          to: "Early Evening"
          entity_id: scene.early_evening
And so on…
That works, thanks a lot!
Awesome. I also got it working! I added
hide_entity: true
So it doesnt show on on the main view
Bump!
I’ve done this on my own, but was wondering instead of having separate automations for each input_select option, is there a more elegant way of passing the chosen option to the action?
Something like
- alias: Trigger Scene from Input Select
    platform: state
    entity_id: input_select.light_scene_selector
    entity_id: scene.{{WHATEVER WAS CHOSEN}}
I also have a “None” initial option. So I’m guessing I’d need some logic (or a blank scene called None) if I were to select it?
Thanks.
I’ve managed to do this, for anyone looking for something similar in the future. Calling the None option doesn’t seem to trigger any errors in the log so I’m just going to leave it.
Config
input_select:
  scene_selector:
    icon: mdi:ceiling-light
    options:
      - None
      - Concentrate
      - Dimmed
      - Reading
      - Relax
      - RedAlert
      - Movie
The the automation to call it.
- id: SceneToConcentrate
  alias: Scene Concentrate
    platform: state
    entity_id: input_select.scene_selector
    data_template:
      entity_id: scene.{{trigger.to_state.state}}
I used the Hue App and HA to record all the scenes it had and then created a select option to switch them, see here – the main difference I notice is that you appear to have multiple aliases/automation(?) per scene whereas I have one to switch depending on choice:
Might help you save some code, helped me out :slight_smile:
