Hi
I have been trying for a few days to install Home Assistant on an Ubuntu Server 16.04 but no success, apparently the version of pip is outdated on Ubuntu 16.04 and i don’t really want to upgrade yet to 18.04 or 16.10.
Does anyone have a straight forward guide? or should I just buy a raspberry pi?
I have seen guides to install it in Docker but I haven’t used Docker before.
Hello guys,
I’m new of Home Assistant. I’m trying to install HA on Ubuntu 18.04, and beaglebone black. The installation stopped at the web page “Preparing Home Assistant” from yesterday. Clicking on the blue button:
21-01-08 20:48:22 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:2021.1.0 -> 404 Client Error for http+docker://localhost/v1.41/images/homeassistant/raspberrypi3-homeassistant:2021.1.0/json: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:2021.1.0: No such image: homeassistant/raspberrypi3-homeassistant:2021.1.0").
21-01-08 20:48:22 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-01-08 20:48:52 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:2021.1.0
21-01-08 20:48:52 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.1.0.
21-01-08 21:04:20 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:2021.1.0 -> 404 Client Error for http+docker://localhost/v1.41/images/homeassistant/raspberrypi3-homeassistant:2021.1.0/json: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:2021.1.0: No such image: homeassistant/raspberrypi3-homeassistant:2021.1.0").
21-01-08 21:04:20 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-01-08 21:04:50 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:2021.1.0
21-01-08 21:04:50 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.1.0.
21-01-08 21:06:03 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-01-08 21:06:03 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-01-08 21:06:03 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
21-01-08 21:06:04 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-01-08 21:12:43 INFO (MainThread) [supervisor.host.info] Updating local host information
21-01-08 21:12:44 INFO (MainThread) [supervisor.host.services] Updating service information
21-01-08 21:12:46 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-01-08 21:12:46 INFO (MainThread) [supervisor.host] Host information reload completed
21-01-08 21:19:40 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:2021.1.0 -> 404 Client Error for http+docker://localhost/v1.41/images/homeassistant/raspberrypi3-homeassistant:2021.1.0/json: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:2021.1.0: No such image: homeassistant/raspberrypi3-homeassistant:2021.1.0").
21-01-08 21:19:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-01-08 21:20:10 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi3-homeassistant:landingpage to homeassistant/raspberrypi3-homeassistant:2021.1.0
21-01-08 21:20:10 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi3-homeassistant with tag 2021.1.0.
