Help with Installing XGBoost
Good afternoon, folks. How are you? My name is Jefferson, I’m from Brazil, and I currently need to run some regression code developed in XGBoost on HomeAssistant, through the AppDaemon add-ons.
I have always used XGBOOST in AppDaemon, and its installation has always been absurdly simple. It only required defining:
system_packages:
  - cmake
  - python3-dev
  - build-base
python_packages:
  - joblib
  - **[u]xgboost[/u]** #XGBOOST definition
init_commands: []
log_level: info
My last installation of xgboost in appdaemon, without any difficulty, was about 4 months ago. At the time I just put: - XGBOOST. as a python package and the system installed it the first time, without any configuration. Therefore, the problem is current (in the last 4 months something has changed and now needs some additional adjustment)
However, now, after a few months without using xgboost, I tried to install it and I’m getting a new and very specific error:
[ 28%] Building CXX object src/CMakeFiles/objxgboost.dir/common/quantile.cc.o
      /tmp/pip-install-20s9s1bl/xgboost_2731b94a814045d3af3ad8ce437fddab/cpp_src/src/common/io.cc: In function 'std::unique_ptr<xgboost::common::**MMAPFile**> xgboost::common::Open(std::string, std::size_t, std::size_t)':
      /tmp/pip-install-20s9s1bl/xgboost_2731b94a814045d3af3ad8ce437fddab/cpp_src/src/common/io.cc:260:38: error: '**mmap64**' was not declared in this scope; did you mean 'mmap'?
        260 |   ptr = reinterpret_cast<std::byte*>(mmap64(nullptr, view_size, prot, MAP_PRIVATE, fd, view_start));
            |                                      mmap
The specific mention of mmap64 suggests that the compilation process expects a 64-bit memory mapping function that may be named or implemented differently in the musl libc environment of Alpine Linux compared to glibc environments.
This has never been an issue, and I never needed to add any other dependency to execute, but currently, I can’t solve it alone.
I’ve tried everything, but I’m not sure how to overcome this limitation. As I need to execute some mathematical models to advance in my postgraduate research, I’m completely stuck JUST BECAUSE OF THIS SIMPLE DETAIL.
Would anyone have a suggestion on some dependency that I could install to fix this mmap64 issue?
Any help would be greatly appreciated.
Thank you in advance.
COMPLETE ERROR:
-- Could NOT find Backtrace (missing: Backtrace_LIBRARY Backtrace_INCLUDE_DIR)
      -- /tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/cpp_src/dmlc-core/cmake/build_config.h.in -> include/dmlc/build_config.h
      -- Configuring done (0.1s)
      -- Generating done (0.0s)
      -- Build files have been written to: /tmp/tmp95dd5ehz/libbuild
      [  2%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io.cc.o
      [  2%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/config.cc.o
      [  3%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/recordio.cc.o
      [  4%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/data.cc.o
      [  5%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/recordio_split.cc.o
      [  6%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/line_split.cc.o
      [  7%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/indexed_recordio_split.cc.o
      [  8%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/input_split_base.cc.o
      [  9%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/filesys.cc.o
      [ 10%] Building CXX object dmlc-core/CMakeFiles/dmlc.dir/src/io/local_filesys.cc.o
      [ 11%] Linking CXX static library libdmlc.a
      [ 11%] Built target dmlc
      [ 12%] Building CXX object src/CMakeFiles/objxgboost.dir/collective/socket.cc.o
      [ 13%] Building CXX object src/CMakeFiles/objxgboost.dir/c_api/c_api_error.cc.o
      [ 14%] Building CXX object src/CMakeFiles/objxgboost.dir/c_api/c_api.cc.o
      [ 15%] Building CXX object src/CMakeFiles/objxgboost.dir/collective/communicator.cc.o
      [ 16%] Building CXX object src/CMakeFiles/objxgboost.dir/collective/in_memory_communicator.cc.o
      [ 17%] Building CXX object src/CMakeFiles/objxgboost.dir/collective/in_memory_handler.cc.o
      [ 18%] Building CXX object src/CMakeFiles/objxgboost.dir/common/charconv.cc.o
      [ 19%] Building CXX object src/CMakeFiles/objxgboost.dir/common/column_matrix.cc.o
      [ 20%] Building CXX object src/CMakeFiles/objxgboost.dir/common/common.cc.o
      [ 21%] Building CXX object src/CMakeFiles/objxgboost.dir/common/error_msg.cc.o
      [ 22%] Building CXX object src/CMakeFiles/objxgboost.dir/common/hist_util.cc.o
      [ 23%] Building CXX object src/CMakeFiles/objxgboost.dir/common/host_device_vector.cc.o
      [ 24%] Building CXX object src/CMakeFiles/objxgboost.dir/common/io.cc.o
      [ 25%] Building CXX object src/CMakeFiles/objxgboost.dir/common/json.cc.o
      [ 26%] Building CXX object src/CMakeFiles/objxgboost.dir/common/numeric.cc.o
      [ 27%] Building CXX object src/CMakeFiles/objxgboost.dir/common/pseudo_huber.cc.o
      /tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/cpp_src/src/common/io.cc: In function 'std::unique_ptr<xgboost::common::MMAPFile> xgboost::common::Open(std::string, std::size_t, std::size_t)':
      /tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/cpp_src/src/common/io.cc:260:38: error: 'mmap64' was not declared in this scope; did you mean 'mmap'?
            |                                      mmap
      make[2]: *** [src/CMakeFiles/objxgboost.dir/build.make:244: src/CMakeFiles/objxgboost.dir/common/io.cc.o] Error 1
      make[2]: *** Waiting for unfinished jobs....
      make[1]: *** [CMakeFiles/Makefile2:264: src/CMakeFiles/objxgboost.dir/all] Error 2
      make: *** [Makefile:156: all] Error 2
        File "/tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/packager/nativelib.py", line 102, in build_libxgboost
          _build(generator=generator)
        File "/tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/packager/nativelib.py", line 68, in _build
          subprocess.check_call([build_tool, f"-j{nproc}"], cwd=build_dir)
        File "/usr/lib/python3.11/subprocess.py", line 413, in check_call
          raise CalledProcessError(retcode, cmd)
      subprocess.CalledProcessError: Command '['make', '-j8']' returned non-zero exit status 2.
        File "/usr/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/usr/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/usr/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel
          whl_basename = backend.build_wheel(metadata_directory, config_settings)
        File "/tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/packager/pep517.py", line 79, in build_wheel
          libxgboost = locate_or_build_libxgboost(
        File "/tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/packager/nativelib.py", line 170, in locate_or_build_libxgboost
          return build_libxgboost(cpp_src_dir, build_dir=build_dir, build_config=build_config)
        File "/tmp/pip-install-pc_4jb3u/xgboost_7ced82f2690f492f8f0a8d295645e2bf/packager/nativelib.py", line 106, in build_libxgboost
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
[18:00:58] FATAL: Failed installing package xgboost
s6-rc: warning: unable to start service init-appdaemon: command exited 1
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This looks like xgboost failing to build due to compiler versions. Upgrading gcc versions and trying to compile old projects often shows this.
I suspect upgrading xgboost may help, if they have committed newer compiler compatibility. EDIT no probably not: that hasn’t changed: current version still expects it to be provided by this include: xgboost/src/common/io.cc at ae68466e28b395d868805e8db22bc117a1f7e539 · dmlc/xgboost · GitHub
Alternatively you could try compiling that with an older version of the compiler.
But the better thing to do would be to understand why xgboost thinkgs that this file should provide that but your current setup doesn’t have it provide it. May be a platform consideration, or a compiler/library bug…
