@shivan could you share your configuration?
Sure it looks like this:
- platform: amcrest host: !secret amcrest_lincoln_host2 name: "Lincoln-old" resolution: low username: !secret camera_username2 password: !secret camera_password2 port: 80 stream_source: rtsp
is it working?
what error are you getting?
Dear all:
my amcrest camera was working well under hass.io
these are my configuration:
amcrest:
host: 192.168.34.109
username: user
password: XXYYZZ
resolution: low
stream_source: mjpeg
sensors:
- motion_detector
- sdcard
camera 1:
platform: amcrest
username: user
password: XXYYZZ
Then, I switched to hassbian.
the very same configuration file no longer works. It give not-so informative error:
Invalid config
The following components and platforms could not be set up:
camera.amcrest amcrest
Please check your config.
Upon further examination, I found something strange in homeassistant.log file:
2018-02-01 22:44:17 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=43 from 2018-02-02 06:37:29.160585)
2018-02-01 22:44:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component amcrest
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 199, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
future.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/amcrest.py", line 99, in setup
device.get(CONF_PASSWORD)).camera
File "/srv/homeassistant/lib/python3.5/site-packages/amcrest/__init__.py", line 32, in __init__
timeout_protocol=timeout_protocol
File "/srv/homeassistant/lib/python3.5/site-packages/amcrest/http.py", line 67, in __init__
self._token = self._generate_token()
File "/srv/homeassistant/lib/python3.5/site-packages/amcrest/http.py", line 82, in _generate_token
req.raise_for_status()
File "/srv/homeassistant/lib/python3.5/site-packages/requests/models.py", line 935, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: http://192.168.34.109:80/cgi-bin/magicBox.cgi?action=getMachineName
2018-02-01 22:44:23 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of camera.amcrest. Setup failed for dependencies: amcrest
2018-02-01 22:44:23 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform camera.amcrest: Could not setup all dependencies.
2018-02-01 22:44:23 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'INSERT INTO events (event_type, event_data, origin, time_fired, created) VALUES (?, ?, ?, ?, ?)'] [parameters: ('service_registered', '{"service": "purge", "domain": "recorder"}', 'LOCAL', '2018-02-02 06:44:16.159696', '2018-02-02 06:44:23.571472')] (Background on this error at: http://sqlalche.me/e/4xp6)
it looks like recorder sqlite file is corrupted?
thanks in advance
This error is not unique to hassbian. It seems that the amcrest.py is not handling authentication correctly. I get a 401 error and Iām sure that the configuration is okay.
There is one error I think I can do something about: that sqlite3.databaseError
if anyone knows where that database is, please let me know. i want to try to delete that data base file and see if it fixes it.
Thanks in advance
you mean something like this?
requests.exceptions.HTTPError: 401 Client Error: Unauthorized for url: http://192.168.23.124:80/cgi-bin/magicBox.cgi?action=getMachineName
The strange thing is thatā¦ amcrest worked fine on my hass.io. itās only when I switched to hassbian i start to encounter this issue.
Unless, it just happened that amcrest updated its script while I was migrating to hassianā¦
I found the sqlite3 database file: home-assistant_v2.db
And I simply deleted it.
it no longer has that sqlite database disk image malformed error, but it still got that 401 authentication error, which is related to amcrest component no longer works with latest amcrest firmware update.
the author of python-amcrest is aware of this issue, I guess we just have to wait.
Same issue with mine. Amcrest was working fine in hassio but when i switched to hassbian i am getting 401 unauthorized for url error.
Anyone resolved this issue? It seems to have been happening to many people.
