I moved from pi3 to a NUC and decided to go with the new SmartThings integration vs MQTT. I am trying to set up my Keen Smart Vents but am having some issues.
- They are added to the light domain. I don’t mind this but if there is an easy solution to switch it to cover. Templates?
- On/Off work but none of the level settings (ie dimming) work.
SmartThings Error when adjusting brightness:
groovy.lang.MissingMethodException: No signature of method: script_dth_d5c37af63c334241606af16f6b7541fb0b787fe92ca27700ae094c8083260d6b.setLevel() is applicable for argument types: (java.lang.Integer, java.lang.Integer) values: [28, 0]
Possible solutions: getLevel(), setLevel(java.lang.Object), ventLevelUp()
Home Assistant Error when adjusting brightness:
DEBUG (MainThread) [homeassistant.components.smartthings] Unable to update status for device: Hassio (6622a384-c542-4c6b-b0de-aef8e4cd5675), the device will be ignored
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/smartthings/__init__.py", line 71, in retrieve_device_status
await device.status.refresh()
File "/usr/local/lib/python3.6/site-packages/pysmartthings/device.py", line 234, in refresh
data = await self._api.get_device_status(self.device_id)
File "/usr/local/lib/python3.6/site-packages/pysmartthings/api.py", line 79, in get_device_status
return await self.get(API_DEVICE_STATUS.format(device_id=device_id))
File "/usr/local/lib/python3.6/site-packages/pysmartthings/api.py", line 314, in get
return await self.request('get', self._api_base + resource, params)
File "/usr/local/lib/python3.6/site-packages/pysmartthings/api.py", line 310, in request
resp.raise_for_status()
File "/usr/local/lib/python3.6/site-packages/aiohttp/client_reqrep.py", line 942, in raise_for_status
headers=self.headers)
aiohttp.client_exceptions.ClientResponseError: 403, message='Forbidden'
2019-02-17 11:40:00 DEBUG (MainThread) [homeassistant.components.smartthings] Unable to update status for device: Keen (930d7078-a711-4a7a-9a6f-3120c18737cd), the device will be ignored
Smartthings Log when turning on or off (works perfect):
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:56 PM: debug Parse returned [:]
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:56 PM: debug cluster: SmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0xe2f1, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x0b, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0540)
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:56 PM: debug parseCatchAllMessage
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:56 PM: debug description: catchall: 0104 0006 01 01 0540 00 E2F1 00 00 0000 0B 01 0000
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:55 PM: debug Parse returned [:]
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:55 PM: debug cluster: SmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00, 0x00], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0xe2f1, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x0b, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0540)
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:55 PM: debug parseCatchAllMessage
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:55 PM: debug description: catchall: 0104 0006 01 01 0540 00 E2F1 00 00 0000 0B 01 0000
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:51 PM: debug makeOnOffResult: 0
2b15b2d2-3526-4279-8b6e-9e06abce031a 1:59:51 PM: debug close Vent - Living Room
For reference, here is my old MQTT for the vent covers:
cover:
- platform: mqtt
name: "Living Room Vent"
retain: true
command_topic: "smartthings/Vent - Living Room/switch/cmd"
state_topic: "smartthings/Vent - Living Room/switch/state"
state_open: 'on'
state_closed: 'off'
payload_open: 'on'
payload_close: 'off'
tilt_command_topic: "smartthings/Vent - Living Room/level/cmd"
tilt_status_topic: "smartthings/Vent - Living Room/level/state"
tilt_min: 0
tilt_max: 100
tilt_closed_value: 0
tilt_opened_value: 100
