I am installing keymaster for my schlage zwave lock. I have followed the instructions to the letter. The last step says the following:
If all goes well, you will also see a new directory (by default <your config directory/packages/keymaster/>
) for each lock with yaml
and a lovelace files. So if you add two integrations, one with FrontDoor and the other with BackDoor, you should see two directories with those names. Inside of each of those directories will be a file called <lockname>_lovelace
. Open that file in a text editor and select the entire contents and copy to the clipboard.
(Open file) Ctrl-A (select all) Ctrl-C (copy)
Open Home Assistant and open the LoveLace editor by clicking the elipses on the top right of the screen, and then select “Configure UI”. Click the elipses again and click “Raw config editor”. Scroll down to the bottom of the screen and then paste your clipboard. This will paste a new View for your lock. Click the Save button then click the X to exit.
When i do this and save it i get the following:
Unable to parse YAML: YAMLException: bad indentation of a mapping entry (62:3) 59 | disabled_mode: true 60 | 61 | 62 | - title: 'frontdoor Codes and C … --------^ 63 | path: keypad-frontdoor 64 | icon: ‘mdi:lock-smart’
Below is the code for the lovelace raw config editor after i paste:
title: Home
- path: default_view
title: Home
visible:
- user: 6a74236da6154bc4a5a1eea84a945e63
badges: []
cards:
- type: weather-forecast
entity: weather.home
show_forecast: false
- type: entities
entities:
- entity: switch.tasmota
icon: hass:water-pump
- entity: switch.tasmota2
icon: hass:fire
- entity: switch.tasmota4
icon: hass:car-light-high
- entity: sensor.pooltempsens_ds18b20_temperature
name: Current Water Temperature
- entity: sensor.current_temp_setting
name: Current Temperature Setting
show_header_toggle: false
state_color: true
- type: entities
entities:
- sensor.timer1
- type: entities
entities:
- entity: input_datetime.only_time
- type: grid
cards:
- type: entities
entities:
- sensor.joel_iphonex_mar19_activity
- sensor.joel_iphonex_mar19_distance
- sensor.joel_iphonex_mar19_floors_ascended
- type: button
tap_action:
action: toggle
show_state: true
resources:
- url: /local/time-picker-card.js
type: module
custom_header:
restrict_users: true
exceptions:
- conditions:
user: 95eb57372b994f0a8ad72917d95cb750
config: {}
split_mode: true
disabled_mode: true
- title: 'frontdoor Codes and Configuration'
icon: 'mdi:lock-smart'
panel: false
badges:
- input_text.frontdoor_lockname
- input_boolean.frontdoor_lock_notifications
- input_boolean.frontdoor_dooraccess_notifications
- input_boolean.frontdoor_garageacess_notifications
- entity: >-
lock.touchscreen_deadbolt_frontdoor
- entity: >-
binary_sensor.fake
- entity: input_datetime.end_date_frontdoor_1
- type: 'custom:fold-entity-row'
head:
type: section
label: Custom Weekdays
entities:
- input_boolean.sun_frontdoor_1
- input_boolean.sun_inc_frontdoor_1
- input_datetime.sun_start_date_frontdoor_1
- input_datetime.sun_end_date_frontdoor_1
- type: divider
- input_boolean.mon_frontdoor_1
- input_boolean.mon_inc_frontdoor_1
- input_datetime.mon_start_date_frontdoor_1
- input_datetime.mon_end_date_frontdoor_1
- type: divider
- input_boolean.tue_frontdoor_1
- input_boolean.tue_inc_frontdoor_1
- input_datetime.tue_start_date_frontdoor_1
- input_datetime.tue_end_date_frontdoor_1
- type: divider
- input_boolean.wed_frontdoor_1
- input_boolean.wed_inc_frontdoor_1
- input_datetime.wed_start_date_frontdoor_1
- input_datetime.wed_end_date_frontdoor_1
- type: divider
- input_boolean.thu_frontdoor_1
- input_boolean.thu_inc_frontdoor_1
- input_datetime.thu_start_date_frontdoor_1
- input_datetime.thu_end_date_frontdoor_1
- type: divider
- input_boolean.fri_frontdoor_1
- input_boolean.fri_inc_frontdoor_1
- input_datetime.fri_start_date_frontdoor_1
- input_datetime.fri_end_date_frontdoor_1
- type: divider
label: Advanced Options
entities:
- entity: input_boolean.reset_codeslot_frontdoor_4
- type: divider
- entity: input_boolean.accesslimit_frontdoor_4
- entity: input_number.accesscount_frontdoor_4
type: 'custom:numberbox-card'
icon: 'mdi:key-variant'
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_4
- entity: input_datetime.start_date_frontdoor_4
- entity: input_datetime.end_date_frontdoor_4
head:
type: section
entities:
- input_boolean.sun_frontdoor_4
- input_boolean.sun_inc_frontdoor_4
- input_datetime.sun_start_date_frontdoor_4
- input_datetime.sun_end_date_frontdoor_4
- type: divider
- input_boolean.mon_frontdoor_4
- input_boolean.mon_inc_frontdoor_4
- input_datetime.mon_start_date_frontdoor_4
- input_datetime.mon_end_date_frontdoor_4
- type: divider
- input_boolean.tue_frontdoor_4
- input_boolean.tue_inc_frontdoor_4
- input_datetime.tue_start_date_frontdoor_4
- input_datetime.tue_end_date_frontdoor_4
- type: divider
- input_boolean.wed_frontdoor_4
- input_boolean.wed_inc_frontdoor_4
- input_datetime.wed_start_date_frontdoor_4
- input_datetime.wed_end_date_frontdoor_4
- type: divider
- input_boolean.thu_frontdoor_4
- input_boolean.thu_inc_frontdoor_4
- input_datetime.thu_start_date_frontdoor_4
- input_datetime.thu_end_date_frontdoor_4
- type: divider
- input_boolean.fri_frontdoor_4
- input_boolean.fri_inc_frontdoor_4
- input_datetime.fri_start_date_frontdoor_4
- input_datetime.fri_end_date_frontdoor_4
- type: divider
- input_boolean.sat_frontdoor_4
- input_boolean.sat_inc_frontdoor_4
- input_datetime.sat_start_date_frontdoor_4
- input_datetime.sat_end_date_frontdoor_4
- type: vertical-stack
cards:
- content: |
## Code 5
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_5
- entity: input_text.frontdoor_pin_5
- entity: input_boolean.enabled_frontdoor_5
- entity: input_boolean.notify_frontdoor_5
- type: divider
- entity: sensor.connected_frontdoor_5
state_color: true
- entity: binary_sensor.active_frontdoor_5
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_5
- type: divider
- entity: input_boolean.accesslimit_frontdoor_5
- entity: input_number.accesscount_frontdoor_5
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_5
- entity: input_datetime.start_date_frontdoor_5
- entity: input_datetime.end_date_frontdoor_5
head:
type: section
entities:
- input_boolean.sun_frontdoor_5
- input_boolean.sun_inc_frontdoor_5
- input_datetime.sun_start_date_frontdoor_5
- input_datetime.sun_end_date_frontdoor_5
- type: divider
- input_boolean.mon_frontdoor_5
- input_boolean.mon_inc_frontdoor_5
- input_datetime.mon_start_date_frontdoor_5
- input_datetime.mon_end_date_frontdoor_5
- type: divider
- input_boolean.tue_frontdoor_5
- input_boolean.tue_inc_frontdoor_5
- input_datetime.tue_start_date_frontdoor_5
- input_datetime.tue_end_date_frontdoor_5
- type: divider
- input_boolean.wed_frontdoor_5
- input_boolean.wed_inc_frontdoor_5
- input_datetime.wed_start_date_frontdoor_5
- input_datetime.wed_end_date_frontdoor_5
- type: divider
- input_boolean.thu_frontdoor_5
- input_boolean.thu_inc_frontdoor_5
- input_datetime.thu_start_date_frontdoor_5
- input_datetime.thu_end_date_frontdoor_5
- type: divider
- input_boolean.fri_frontdoor_5
- input_boolean.fri_inc_frontdoor_5
- input_datetime.fri_start_date_frontdoor_5
- input_datetime.fri_end_date_frontdoor_5
- type: divider
- input_boolean.sat_frontdoor_5
- input_boolean.sat_inc_frontdoor_5
- input_datetime.sat_start_date_frontdoor_5
- input_datetime.sat_end_date_frontdoor_5
cards:
- content: |
## Code 6
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_6
- entity: input_text.frontdoor_pin_6
- entity: input_boolean.enabled_frontdoor_6
- entity: input_boolean.notify_frontdoor_6
- type: divider
- entity: sensor.connected_frontdoor_6
state_color: true
- entity: binary_sensor.active_frontdoor_6
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_6
- type: divider
- entity: input_boolean.accesslimit_frontdoor_6
- entity: input_number.accesscount_frontdoor_6
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_6
- entity: input_datetime.start_date_frontdoor_6
- entity: input_datetime.end_date_frontdoor_6
head:
type: section
entities:
- input_boolean.sun_frontdoor_6
- input_boolean.sun_inc_frontdoor_6
- input_datetime.sun_start_date_frontdoor_6
- input_datetime.sun_end_date_frontdoor_6
- type: divider
- input_boolean.mon_frontdoor_6
- input_boolean.mon_inc_frontdoor_6
- input_datetime.mon_start_date_frontdoor_6
- input_datetime.mon_end_date_frontdoor_6
- type: divider
- input_boolean.tue_frontdoor_6
- input_boolean.tue_inc_frontdoor_6
- input_datetime.tue_start_date_frontdoor_6
- input_datetime.tue_end_date_frontdoor_6
- type: divider
- input_boolean.wed_frontdoor_6
- input_boolean.wed_inc_frontdoor_6
- input_datetime.wed_start_date_frontdoor_6
- input_datetime.wed_end_date_frontdoor_6
- type: divider
- input_boolean.thu_frontdoor_6
- input_boolean.thu_inc_frontdoor_6
- input_datetime.thu_start_date_frontdoor_6
- input_datetime.thu_end_date_frontdoor_6
- type: divider
- input_boolean.fri_frontdoor_6
- input_boolean.fri_inc_frontdoor_6
- input_datetime.fri_start_date_frontdoor_6
- input_datetime.fri_end_date_frontdoor_6
- type: divider
- input_boolean.sat_frontdoor_6
- input_boolean.sat_inc_frontdoor_6
- input_datetime.sat_start_date_frontdoor_6
- input_datetime.sat_end_date_frontdoor_6
cards:
- content: |
## Code 7
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_7
- entity: input_text.frontdoor_pin_7
- entity: input_boolean.enabled_frontdoor_7
- entity: input_boolean.notify_frontdoor_7
- type: divider
- entity: sensor.connected_frontdoor_7
state_color: true
- entity: binary_sensor.active_frontdoor_7
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_7
- type: divider
- entity: input_boolean.accesslimit_frontdoor_7
- entity: input_number.accesscount_frontdoor_7
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_7
- entity: input_datetime.start_date_frontdoor_7
- entity: input_datetime.end_date_frontdoor_7
head:
type: section
entities:
- input_boolean.sun_frontdoor_7
- input_boolean.sun_inc_frontdoor_7
- input_datetime.sun_start_date_frontdoor_7
- input_datetime.sun_end_date_frontdoor_7
- type: divider
- input_boolean.mon_frontdoor_7
- input_boolean.mon_inc_frontdoor_7
- input_datetime.mon_start_date_frontdoor_7
- input_datetime.mon_end_date_frontdoor_7
- type: divider
- input_boolean.tue_frontdoor_7
- input_boolean.tue_inc_frontdoor_7
- input_datetime.tue_start_date_frontdoor_7
- input_datetime.tue_end_date_frontdoor_7
- type: divider
- input_boolean.wed_frontdoor_7
- input_boolean.wed_inc_frontdoor_7
- input_datetime.wed_start_date_frontdoor_7
- input_datetime.wed_end_date_frontdoor_7
- type: divider
- input_boolean.thu_frontdoor_7
- input_boolean.thu_inc_frontdoor_7
- input_datetime.thu_start_date_frontdoor_7
- input_datetime.thu_end_date_frontdoor_7
- type: divider
- input_boolean.fri_frontdoor_7
- input_boolean.fri_inc_frontdoor_7
- input_datetime.fri_start_date_frontdoor_7
- input_datetime.fri_end_date_frontdoor_7
- type: divider
- input_boolean.sat_frontdoor_7
- input_boolean.sat_inc_frontdoor_7
- input_datetime.sat_start_date_frontdoor_7
- input_datetime.sat_end_date_frontdoor_7
cards:
- content: |
## Code 8
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_8
- entity: input_text.frontdoor_pin_8
- entity: input_boolean.enabled_frontdoor_8
- entity: input_boolean.notify_frontdoor_8
- type: divider
- entity: sensor.connected_frontdoor_8
state_color: true
- entity: binary_sensor.active_frontdoor_8
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_8
- type: divider
- entity: input_boolean.accesslimit_frontdoor_8
- entity: input_number.accesscount_frontdoor_8
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_8
- entity: input_datetime.start_date_frontdoor_8
- entity: input_datetime.end_date_frontdoor_8
head:
type: section
entities:
- input_boolean.sun_frontdoor_8
- input_boolean.sun_inc_frontdoor_8
- input_datetime.sun_start_date_frontdoor_8
- input_datetime.sun_end_date_frontdoor_8
- type: divider
- input_boolean.mon_frontdoor_8
- input_boolean.mon_inc_frontdoor_8
- input_datetime.mon_start_date_frontdoor_8
- input_datetime.mon_end_date_frontdoor_8
- type: divider
- input_boolean.tue_frontdoor_8
- input_boolean.tue_inc_frontdoor_8
- input_datetime.tue_start_date_frontdoor_8
- input_datetime.tue_end_date_frontdoor_8
- type: divider
- input_boolean.wed_frontdoor_8
- input_boolean.wed_inc_frontdoor_8
- input_datetime.wed_start_date_frontdoor_8
- input_datetime.wed_end_date_frontdoor_8
- type: divider
- input_boolean.thu_frontdoor_8
- input_boolean.thu_inc_frontdoor_8
- input_datetime.thu_start_date_frontdoor_8
- input_datetime.thu_end_date_frontdoor_8
- type: divider
- input_boolean.fri_frontdoor_8
- input_boolean.fri_inc_frontdoor_8
- input_datetime.fri_start_date_frontdoor_8
- input_datetime.fri_end_date_frontdoor_8
- type: divider
- input_boolean.sat_frontdoor_8
- input_boolean.sat_inc_frontdoor_8
- input_datetime.sat_start_date_frontdoor_8
- input_datetime.sat_end_date_frontdoor_8
cards:
- content: |
## Code 9
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_9
- entity: input_text.frontdoor_pin_9
- entity: input_boolean.enabled_frontdoor_9
- entity: input_boolean.notify_frontdoor_9
- type: divider
- entity: sensor.connected_frontdoor_9
state_color: true
- entity: binary_sensor.active_frontdoor_9
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_9
- type: divider
- entity: input_boolean.accesslimit_frontdoor_9
- entity: input_number.accesscount_frontdoor_9
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_9
- entity: input_datetime.start_date_frontdoor_9
- entity: input_datetime.end_date_frontdoor_9
head:
type: section
entities:
- input_boolean.sun_frontdoor_9
- input_boolean.sun_inc_frontdoor_9
- input_datetime.sun_start_date_frontdoor_9
- input_datetime.sun_end_date_frontdoor_9
- type: divider
- input_boolean.mon_frontdoor_9
- input_boolean.mon_inc_frontdoor_9
- input_datetime.mon_start_date_frontdoor_9
- input_datetime.mon_end_date_frontdoor_9
- type: divider
- input_boolean.tue_frontdoor_9
- input_boolean.tue_inc_frontdoor_9
- input_datetime.tue_start_date_frontdoor_9
- input_datetime.tue_end_date_frontdoor_9
- type: divider
- input_boolean.wed_frontdoor_9
- input_boolean.wed_inc_frontdoor_9
- input_datetime.wed_start_date_frontdoor_9
- input_datetime.wed_end_date_frontdoor_9
- type: divider
- input_boolean.thu_frontdoor_9
- input_boolean.thu_inc_frontdoor_9
- input_datetime.thu_start_date_frontdoor_9
- input_datetime.thu_end_date_frontdoor_9
- type: divider
- input_boolean.fri_frontdoor_9
- input_boolean.fri_inc_frontdoor_9
- input_datetime.fri_start_date_frontdoor_9
- input_datetime.fri_end_date_frontdoor_9
- type: divider
- input_boolean.sat_frontdoor_9
- input_boolean.sat_inc_frontdoor_9
- input_datetime.sat_start_date_frontdoor_9
- input_datetime.sat_end_date_frontdoor_9
cards:
- content: |
## Code 10
type: markdown
- type: entities
entities:
- entity: input_text.frontdoor_name_10
- entity: input_text.frontdoor_pin_10
- entity: input_boolean.enabled_frontdoor_10
- entity: input_boolean.notify_frontdoor_10
- type: divider
- entity: sensor.connected_frontdoor_10
state_color: true
- entity: binary_sensor.active_frontdoor_10
state_color: true
head:
type: section
entities:
- entity: input_boolean.reset_codeslot_frontdoor_10
- type: divider
- entity: input_boolean.accesslimit_frontdoor_10
- entity: input_number.accesscount_frontdoor_10
speed: 250
- type: divider
- entity: input_boolean.daterange_frontdoor_10
- entity: input_datetime.start_date_frontdoor_10
- entity: input_datetime.end_date_frontdoor_10
head:
type: section
entities:
- input_boolean.sun_frontdoor_10
- input_boolean.sun_inc_frontdoor_10
- input_datetime.sun_start_date_frontdoor_10
- input_datetime.sun_end_date_frontdoor_10
- type: divider
- input_boolean.mon_frontdoor_10
- input_boolean.mon_inc_frontdoor_10
- input_datetime.mon_start_date_frontdoor_10
- input_datetime.mon_end_date_frontdoor_10
- type: divider
- input_boolean.tue_frontdoor_10
- input_boolean.tue_inc_frontdoor_10
- input_datetime.tue_start_date_frontdoor_10
- input_datetime.tue_end_date_frontdoor_10
- type: divider
- input_boolean.wed_frontdoor_10
- input_boolean.wed_inc_frontdoor_10
- input_datetime.wed_start_date_frontdoor_10
- input_datetime.wed_end_date_frontdoor_10
- type: divider
- input_boolean.thu_frontdoor_10
- input_boolean.thu_inc_frontdoor_10
- input_datetime.thu_start_date_frontdoor_10
- input_datetime.thu_end_date_frontdoor_10
- type: divider
- input_boolean.fri_frontdoor_10
- input_boolean.fri_inc_frontdoor_10
- input_datetime.fri_start_date_frontdoor_10
- input_datetime.fri_end_date_frontdoor_10
- type: divider
- input_boolean.sat_frontdoor_10
- input_boolean.sat_inc_frontdoor_10
- input_datetime.sat_start_date_frontdoor_10
- input_datetime.sat_end_date_frontdoor_10
