Help with LaMetric configuration
reading the Documentation I am confused on something.
the configuration example;
# Example configuration.yaml entry
notify:
  platform: lametric
then the automation refers to;
    service: notify.lametric
I read that the that the name: should be appended to the the notify
So do the two code example not go together, meaning the automation refers to a service not in the configuration, or am I missing how to stitch this together.
Thank You
figured this out, they are NOT part of a flow.
If the name: is NOTIFIER_NAME then the service: is notify.NOTIFIER_NAME
to an expert this probably was obvious for a novice the use of lametric was confusing, and I assume would work if there was no option name: in the configuration.yaml
For clarity, the automation.yaml for the configuration.yaml shown would be
    service: notify.NOTIFIER_NAME
Except the docs say that upper case isn’t valid. Which will be why it’s used, to make it stand out as a thing to replace.
Generally speaking, after you create a new entity or service, you should look in Developer Tools -> States or Developer Tools -> Services to see what it’s actually called. HA will automatically “slugify” names to make them HA safe, which can cause things to change more than you expect.
Did not know the upper case rule, as it actually works with upper case, and furthers the ‘novice’ confusion.
I will try the developer tool section, Thank You for the TIP I was stumbling through trying to find them.
Issues like: The integration states that you use the name: to have multiple notifyers, but when I put two in the last one seems to usurp the others.
Tried it with two sections each starting with notify: changing definition and one notify: with two sections each starting with a different name:
I greatly appreciate the help. GREAT learning
You probably want to read this page too, on the fact that you can’t use notify: twice.
