I have a newLutron RadioRA2 system with ~175 switches/dimmers/keypads throughout the house. I am trying to get the system and all the entities up on Home assistant.
I have initially used the Lutron HomeKit integration, but I have way exceeded the 150 entity limit for HomeKit. (Each button on the 6 button keypad is a separate entity).
I’m hoping someone here can help. I am relatively new to HA — just getting the system up and running — so please excuse me if these are too basic.
- Is there a different Lutron integration to use? Lutron - Home Assistant seems to refer to a native, non-HomeKit integration. I do have the lutron code in configuration.yaml, and I can telnet into the main repeater with these credentials/ip address, but the entities only show up under the homekit integration.,
lutron:
host: 192.168.1.201
username: xxxx
password: xxxx
When I enter my HomeKit paring code on this integration, I get a message “Invalid Flow Specified”. The entities (at least, 150 of them) still show up show I am not sure what this is referring to. The HA logs are below.
On the HomeKit integration, if that is the way to go, I am trying to figure out how to filter by type to use different HomeKit bridges. Does anyone have a good reference code I can crib from to do this with a Lutron system?
Alternatively, I am considering using Hubitat as a bridge to the Lutron system. Does anyone have any experience with this, and does it work better than the native Lutron integration?
Thanks — appreciate the help.
[finish] process exit code 0
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2022-03-31 12:20:15 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-03-31 12:20:19 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2022-03-31 12:20:31 WARNING (MainThread) [homeassistant.setup] Setup of lutron is taking over 10 seconds.
2022-03-31 12:21:11 ERROR (MainThread) [homeassistant.components.hassio.handler] /addons return code 500
2022-03-31 12:21:11 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /addons -
2022-03-31 12:21:11 ERROR (MainThread) [homeassistant.components.hassio.handler] /store return code 500
2022-03-31 12:21:11 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /store -
2022-03-31 12:21:21 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: cover.lutron, switch.lutron, light.lutron
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.cabana_cabana_entry_kp_led_track_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.cabana_cabana_entry_kp_sconces_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.cabana_cabana_entry_kp_cb_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.cabana_cabana_entry_kp_room_off_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_enter_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_floor_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_outside_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_all_off_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_front_door_kp_led_2 as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_entry_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_gar_spots_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_outside_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_all_off_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_hall_mud_rm_kp_room_off_led as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.main_hall_living_rm_hall_kp_room_on_led as this would exceed the 150 device limit. Consider using the filter option
[…EDITED OUT A FEW HUNDRED OF THESE…]
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add media_player.office as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.dojo_dojo_led_track as this would exceed the 150 device limit. Consider using the filter option
2022-03-31 12:21:28 WARNING (MainThread) [homeassistant.components.homekit] Cannot add switch.gym_gym_led_track as this would exceed the 150 device limit. Consider using the filter option
