Help with light automation with motion
Hi I’ve just started using home assistant after taking the leap from SmartThings and would like to do something like Reed has done in webcore (i originally had this working using web core but I cannot for the love of money work out how to do it in HA.
I would like the lights in the room to stay on for 10 seconds if motion was less than a minute and on for 5 mins if morion was detected for more than 1 minute.
Can someone please help a complete Noob?
Video in question below.
Robb
Let simplify with 2 automations - you can combine with trigger id
The on is simple but you will need a Timer helper.
Here is how I envision it working
Trigger - Motion goes from off to on
Condition - Light is off
Action - Turn on light(s)
Action - Set Timer to 61 seconds
Trigger - Motion goes from on to off
Condition - Light is on
Action - Choose
Condition - Timer is idle
Action - delay 300 seconds
Action - Turn off light(s)
Condition - Default
Action delay 10 seconds
You can create all of this from the UI.
Does this get you to where you want to be?
Edit - I built all of this from the UI and copied the yaml.
alias: turn on light
description: ''
mode: single
  - platform: state
    entity_id: binary_sensor.shellymotionsensor_60a423c66d96_motion
    to: 'on'
condition:
  - condition: state
    entity_id: light.study_cans_current_value
    state: 'off'
  - service: light.turn_on
      brightness_pct: 98
- service: timer.start
      duration: '61'
      entity_id: timer.mechanicalroom_timer
alias: turn off light
description: ''
mode: single
  - platform: state
    to: 'off'
condition:
  - condition: state
    state: 'on'
  - choose:
      - conditions:
          - condition: state
            state: 'idle'
        sequence:
          - delay:
              hours: 0
              minutes: 0
              seconds: 60
              milliseconds: 0
          - service: light.turn_off
    default:
      - delay:
          hours: 0
          minutes: 0
          seconds: 10
          milliseconds: 0
That’s fantastic. Let me try and I’ll let you know.
That seemed to work a treat. Thanks :grinning:
