Logger: homeassistant.components.automation.vc_master_lambs
Source: components/automation/init.py:744
integration: Automation (documentation, issues)
First occurred: 7:09:57 AM (1 occurrences)
Last logged: 7:09:57 AM
Error while executing automation automation.vc_master_lambs:
I head over to my automation.yaml file… and there are no automatons called vc_master_lambs
Do I need to be concerned about errors like this?
How do I resolve this?
System seems fine…
Did you recently rename an automation from that name via the UI? If you look in Developer Tools > States and search on that name, does anything come up?
Yes, the “lamb” was a renamed typo… I changed the name… and at least now I can tie the error to a specific switch… It is a Zooz ZEN21… on old firmware… I’m doing a firmware update to see if the error goes away.
A Firmware update on the old ZEN21 solves the Log issues… Thanks for your help
