Help with log
Hi Guys,
I am trying to give a new samsung tv remote a try and noticed my log had a lot of stuff.
Can anyone help me figure out how to fix this stuff?
2019-12-07 18:53:17 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=160 from 2019-12-08 02:46:04.043199)
2019-12-07 18:53:17 WARNING (MainThread) [homeassistant.components.mqtt.sensor] configuration variable "json_attributes" is deprecated, replace with "json_attributes_topic"
2019-12-07 18:53:18 WARNING (MainThread) [homeassistant.components.mqtt.sensor] configuration variable "json_attributes" is deprecated, replace with "json_attributes_topic"
2019-12-07 18:53:20 WARNING (MainThread) [homeassistant.loader] You are using a custom component for samsungtv_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-12-07 18:53:28 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 56, in async_setup_component
    return await task  # type: ignore
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
    result = coro.send(None)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 124, in _async_setup_component
    conf_util.async_process_component_config(hass, config, domain)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config.py", line 749, in async_process_component_config
    platform = get_platform(hass, domain, p_name)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 97, in get_platform
    base_paths)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/loader.py", line 166, in _load_file
    module = importlib.import_module(path)
  File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 986, in _gcd_import
  File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 669, in exec_module
  File "<frozen importlib._bootstrap_external>", line 775, in get_code
  File "<frozen importlib._bootstrap_external>", line 735, in source_to_code
  File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
  File "/home/homeassistant/.homeassistant/custom_components/samsungtv_custom/media_player.py", line 119
    name = f"{tv_name} ({model})"
SyntaxError: invalid syntax
2019-12-07 18:54:08 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/discovery/__init__.py", line 181, in new_service_found
    hass, component, platform, info, config)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/discovery.py", line 161, in async_load_platform
    hass, component, hass_config)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 45, in async_setup_component
    return await setup_tasks[domain]  # type: ignore
  File "/usr/lib/python3.5/asyncio/futures.py", line 382, in __iter__
    return self.result()  # May raise too.
    future.result()
    base_paths)
You should raise an issue with the custom component developer.
Some of it is there, but some is elsewhere like python.
