I need some help keeping one item from flooding my logs. Apparently I’m one of the only people getting this error because I cannot find anyone else reporting this. I’m ok with that. But I would like to keep it from flooding my logs
This is the error
2020-10-29 17:33:09 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/connection.py", line 249, in async_process_entity_map
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/connection.py", line 363, in async_update
new_values_dict = await self.get_characteristics(
File "/usr/src/homeassistant/homeassistant/components/homekit_controller/connection.py", line 399, in get_characteristics
return await self.pairing.get_characteristics(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/aiohomekit/controller/ip/pairing.py", line 234, in get_characteristics
return format_characteristic_list(response)
File "/usr/local/lib/python3.8/site-packages/aiohomekit/controller/ip/pairing.py", line 44, in format_characteristic_list
key = (c["aid"], c["iid"])
KeyError: 'aid'
I can of course set this in my configuration.yaml
logger:
default: warning
logs:
homeassistant: fatal
but then I pretty much get nothing in my logs at all. I’d like just to not get the errors above. I suspect the answer is “cant do that”, but was hoping someone might know a trick.
Thanks in advance
