Help with logic & syntaxing for a light toggle
Hi all,
Hoping for some guidence with logic.
I have a bedside light and a kodi instance
I have a flic button that I have been playing with which does the follwoing:
Single Click = light.toggle
DoubleClick = light.toggle & media_player.media_play_pause
So on a double click kodi pauses and turns my light on, I pop off and do someting, come back, double click for the light to turn off and kodi to resume.
  • alias: Pause & Toggle Bedside
    platform: event
    event_type: flic_click
    event_data:
    button_name: flic_80e4da723c3a
    click_type: double
    • service: media_player.media_play_pause
      entity_id: media_player.kodi__atv
    • service: light.toggle
      entity_id: light.bedside
This all works well until either the light is already on or kodi is already paused. Then things go out of sync so Im looking to put a bit of logic around the toggle.
I’ve been working through some things but I just cant seem to get it.
The last bit I tried was:
  event_data:
    click_type: double
- service: media_player.media_play_pause
- service_template: light.{%- if is_state('media_player.kodi__atv', 'paused') -%}turn_on{%- elif is_state('media_player.kodi__atv', 'playing') -%}turn_off{%- else -%}turn_off{%- endif -%}
Basically using kodis state and testing against the curent light state to decide what action to take. This way, no matter what state either is in, they wont get out of sync.
Im struggling with a) the syntaxing and b) if this is actually the right way to go about it.
Hoping someone would be able to advise?
Have you tried the template editor to see if your service template syntax is providing you the expected results?
Sorry, had to shelve this for a bit as had an influx of new devices to add and setup :slight_smile:
Taking another look at this now.
So, in the template editor:
Results:
Kodi playing: light.turn_off
Kodi paused: light.turn_on
The first part of the logic seems to be working but it still goes wonky.
If I pause kodi and turn the light on, the result goes back to: light.turn_on
If I then play kodi the result changes to: light.turn_off
If I then pause kodi the result changes to: light.turn_on - Getting things out of sync again.
I feel like I need another bit of logic in there somewhere to test against the state of the light at the time the button is pressed and match against the state of kodi but I have no idea how to do that!
What you might do is make the light or Kodi master and the other slave. Then if you double click, toggle master and sync slave to that state.
Aaaa so something Along the lines of: (butchered from How to Do on / OFF group switch)
state = hass.states.get(data['master']).state
if state == 'paused':
    hass.services.call('homeassistant', 'turn_off',
                       {'entity_id': data['slave']})
else if state == 'playing':
    hass.services.call('homeassistant', 'turn_on', {
      platform: event
      event_data:
        click_type: double
    service: python_script.kodi_toggle
      master: mediaplayer.kodi
      slave: light.bedside
This earlier example of yours looks like the right way to do this.
My approach:
automation:
  - alias: Double Click Flic
      event_data:
        click_type: double
      # toggle master
      # ---> if needed, build in a delay here
      # sync slave
      # ... syncs playing state with lights on. you can also revert and sync with state 'paused'
      - service_template: >
        {% if is_state('media_player.kodi__atv', 'playing') %}
          light.turn_on
        {% else %}
          light.turn_off
        {% endif %}
Thats just wonderful mate!
When I first started, I got close to something like this but with multiple if/elses for each condition which worked but really wonky and about 90 lines! Nothing as fluid as this.
Just tested and it works perfectly :smiley:
