Help with mini-media-player shortcuts
Hi All,
I am trying to get some shortcut buttons created for the mini-media-player card. Specifically I want the buttons to change the source of the receiver to which this card points. I realize there is a dropdown for Source but I am hoping to get this to work instead.
type: custom:mini-media-player
entity: media_player.basement_receiver
toggle_power: true
volume_stateless: true
artwork: material
source: full
icon: mdi:television
sound_mode: full
info: scroll
max_volume: '100'
min_volume: '1'
shortcuts:
  columns: 4
  buttons:
    - icon: mdi:television
      service: media_player.select_source
        source: TV
I keep getting the following error:
Failed to call service media_player/play_media. required key not provided @ data['media_content_type']
I have tried adding the entity ID into the data block as well as changing the data block to be servic_data.
If I add media_content_type: video, still no dice.
Anyone have any ideas what I am doing wrong here?
As you’re using the mini-media-player card you have to use the commands that it provides. Which means your code becomes simpler
My example below:
shortcuts:
  label: Select Input
  hide_when_off: true
  list:
    - name: Shield
      type: source
Which means I’d expect yyours to change from:
shortcuts:
  columns: 4
  buttons:
        source: TV
to
shortcuts:
  columns: 4
  buttons:
      type: source
