I’m trying tro write an automation to do the following:
if the camera sensor is above a certain value (trigger), the sun is down AND the led is off, AND me OR my so are home, turn on the led.
this is what i have in my automations.yaml:
- alias: 'Nightlights'
- above: '100'
entity_id: sensor.desirecam_motion
platform: numeric_state
condition:
condition: and
conditions:
- condition: state
entity_id: 'light.led_strip'
state: off
- condition: state
entity_id: 'sun.sun'
state: 'below_horizon'
- condition: or
conditions:
- condition: state
entity_id: 'device_tracker.lorenzo'
state: 'home'
- condition: state
entity_id: 'device_tracker.ilaria'
state: 'home'
- data:
entity_id: light.led_strip
service: light.turn_on
But i keep getting errors, no matter what i change. if i remove the conditions completely it seems to work, so there may be something wrong with that…
2018-02-10 14:19:35 ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: extra keys not allowed @ data['condition'][0]['conditions'][0]['state']. Got None
not a valid value for dictionary value @ data['condition'][0]['conditions'][0]['condition']. Got None. (See /home/homeassistant/.homeassistant/configuration.yaml, line 126). Please check the docs at https://home-assistant.io/components/automation/
I’m following the docs here: https://home-assistant.io/docs/scripts/conditions/
