Help with Motion light config
Good morning. I’m having a weird problem regarding motion controlled lighting. I have tried a couple different blueprints and I have the same results regardless of the blueprint. I should mention that these switches were used previously in smartthings for a similar automation. I set them up to turn on when motion is detected and then off after a period of time. I have some that are longer wait times (ie. 15 minutes on one and 45 on another). Regardless of the automation, or the room…the lights turn off after about a minute and a half (90 seconds). Nothing seems to “fix” this (ie. different blueprint, different motion detectors, different switch, brands etc). Any suggestion on what I could do to rectify. Below is a copy of the blueprint code I’m using. And also a copy of one of the automations.
blueprint:
  description: Turn on a light when motion is detected.
  domain: automation
  source_url: https://github.com/home-assistant/core/blob/11f80762eabf9e0a3c21395e7ae9cd8d939016ea/homeassistant/components/automation/blueprints/motion_light.yaml
  input:
    motion_entity:
      selector:
        entity:
          domain: binary_sensor
          device_class: motion
    switch_target:
      selector:
          entity:
            domain: switch
    no_motion_wait:
      description: Time to leave the light on after last motion is detected.
      default: 120
      selector:
        number:
          min: 0
          max: 3600
          unit_of_measurement: minutes
# If motion is detected within the delay,
# we restart the script.
mode: restart
max_exceeded: silent
  platform: state
  entity_id: !input motion_entity
  to: "on"
  - alias: "Turn on the light"
    service: switch.turn_on
    target: !input switch_target
  - alias: "Wait until there is no motion from device"
    wait_for_trigger:
      platform: state
      to: "off"
  - alias: "Wait the number of minutes that has been set"
    delay: !input no_motion_wait
  - alias: "Turn off the light"
    service: switch.turn_off
I just wanted to follow up on this. I went through the debug trace on the automation and it appears that despite “unit_of_measure: minutes” being in the code, it was still using seconds. I’m not sure why. I entered the number I wanted in seconds and everything appears to be working as expected.
