So I have this Python code that uses Accuweather api to get the predicted temperature 12 hours in advance. I want to move this value to Home Assistant to trigger a relay if certain conditions are met. I’ve made the python_scripts folder and the set up for it.
import requests
import json
import datetime
import pytz
# API key from AccuWeather Developer Portal
api_key = "redacted"
# Location key for the desired location
location_key = "326854"
def get_future_temp():
global temp
# Make API call to AccuWeather API
response = requests.get(f"http://dataservice.accuweather.com/forecasts/v1/hourly/12hour/{location_key}?apikey={api_key}&metric=false")
# Parse JSON response
data = json.loads(response.text)
# Extract the hourly temperatures and times for the next day
next_day_temperatures = []
next_day_times = []
for forecast in data:
time = datetime.datetime.fromisoformat(forecast["DateTime"].split("+")[0]).replace(tzinfo=pytz.UTC)
if time >= datetime.datetime.now(pytz.UTC) and time <= datetime.datetime.now(pytz.UTC) + datetime.timedelta(days=1):
next_day_times.append(time.strftime("%Y-%m-%d %H:%M:%S"))
next_day_temperatures.append(forecast["Temperature"]["Value"])
# Gets closes temperature and time to the next day
temp = next_day_temperatures[-1]
return(temp)
get_future_temp()
Is it possible to send this value to Home Assistant, if so how? I’m pretty new to HA.
