Help with MQTT sensor and attributes
sadly i need some more help with MQTT sensors :slight_smile:
This is an example of my mqtt data (as you can see, i have a json inside a json field)
{"timestamp": 1686941544.2616673,
"data":
	"{\"1\":
		{\"roomId\": 1, \"roomName\": \"Sala\", \"actualTemp\": 27.6, \"setTemp\": 20.0, \"valveAperture\": 0, \"status\": true},
	\"2\":
		{\"roomId\": 2, \"roomName\": \"Cucina\", \"actualTemp\": 28.0, \"setTemp\": 19.0, \"valveAperture\": 0, \"status\": false},
	\"3\":
		{\"roomId\": 3, \"roomName\": \"Bagnetto\", \"actualTemp\": 27.1, \"setTemp\": 19.0, \"valveAperture\": 0, \"status\": false},
	\"4\":
		{\"roomId\": 4, \"roomName\": \"Bagno\", \"actualTemp\": 27.2, \"setTemp\": 19.0, \"valveAperture\": 0, \"status\": false},
	\"5\":
		{\"roomId\": 5, \"roomName\": \"Camera\", \"actualTemp\": 27.4, \"setTemp\": 19.5, \"valveAperture\": 0, \"status\": false},
	\"6\":
		{\"roomId\": 6, \"roomName\": \"Studio\", \"actualTemp\": 27.6, \"setTemp\": 19.0, \"valveAperture\": 0, \"status\": false}}
Now i’d like to create 6 sensors, one for each room, where the value is the actual temp and as attributes i’d have valve aperture, target temp and the status.
I tried with something like that:
#temperatures
    - name: "Temperature Room 1"
      state_topic: massi/sensors/roomTemp
      value_template: "{{ value_json.data[1].actualTemp }}"
      suggested_display_precision: 1
      unit_of_measurement: "°C"
      json_attributes_topic: massi/sensors/roomTemp
      json_attributes_template: >
        { "targetTemp": {{ value_json.data[1].setTemp }},
          "valveAperture": {{ value_json.data[1].valveAperture }},
          "statusError": {{ value_json.data[1].status }}
obviously nothing works :slight_smile: The point - i think - is that the nested json is not parsed. Indeed i get this error:
Template variable warning: 'str object' has no attribute 'actualTemp' when rendering '{{ value_json.data[1].actualTemp }}'
but i’ve not understood how to get this parsed.
I’d also like to add:
  • how can i set the unit of measurement of attributes?
  • are also attributes logged and graph-ed?
  • do you see anything very very wrong in what i’m trying to do? :slight_smile:
As far as HA is concerned, everything under “data” is one big plain string, not json, so you cannot use json parsing here.
Maybe some clever jinja substring will do, but it will be tricky.
Odd that your device would do that. But this will work:
        {% set info = value_json.data[1] | from_json %}
        { "targetTemp": {{ info.setTemp }},
          "valveAperture": {{ info.valveAperture }},
          "statusError": {{ info.status }}
Nice.
Likely
      value_template: >
        {% set info = value_json.data | from_json %}
        {{ info["1"].actualTemp }}
        { "targetTemp": {{ info["1"].setTemp }},
          "valveAperture": {{ info["1"].valveAperture }},
          "statusError": {{ info["1"].status }}
or similar, though.
I actually have no clue on the scope of a jinja variable. Could “info” be reused in json_attributes_template as well?
You can only reuse info inside each field. We are both wrong btw… after looking at his data (was focused on the json), this is the correct template:
      value_template: >
        {{ info.actualTemp }}
Mmm… Not sure, after from_json, “info” is
  "1": {
    "roomId": 1,
    "roomName": "Sala",
    "actualTemp": 27.6,
    "setTemp": 20.0,
    "valveAperture": 0,
    "status": true
  "2": {
    "roomId": 2,
    "roomName": "Cucina",
    "actualTemp": 28.0,
    "setTemp": 19.0,
    "valveAperture": 0,
    "status": false
  "3": {
    "roomId": 3,
    "roomName": "Bagnetto",
    "actualTemp": 27.1,
    "setTemp": 19.0,
    "valveAperture": 0,
    "status": false
  "4": {
    "roomId": 4,
    "roomName": "Bagno",
    "actualTemp": 27.2,
    "setTemp": 19.0,
    "valveAperture": 0,
    "status": false
  "5": {
    "roomId": 5,
    "roomName": "Camera",
    "actualTemp": 27.4,
    "setTemp": 19.5,
    "valveAperture": 0,
    "status": false
  "6": {
    "roomId": 6,
    "roomName": "Studio",
    "actualTemp": 27.6,
    "setTemp": 19.0,
    "valveAperture": 0,
    "status": false
Ugh, need my morning wakeup juice
OP, keep in mind the quotes in info["1"] are relevant.
info[1] would assume info is an array, which it isn’t.
guys you are amazing!
I can now get the temperature
However, attributes are not working since i get this error:
Erroneous JSON: { "targetTemp": 19.5, "valveAperture": 0, "statusError": True }
this is not the source json (it’s using attributes names as keys), i can’t understand this :slight_smile:
Do you also know if i can set also a unit of measurement for each attribute?
Thanks!!
whatever is outputting that is not formatting in JSON, so when attempts to translate it to json, it fails. It’s because json doesn’t understand True, only true. IMO you should fix whatever is populating that information to ensure it outputs proper json.
this is VERY strange, since the json comes from a python script generating it with
output['data'] = json.dumps(data)
afaik this manages correct capital letters, isn’t it?
yes but you already have other oddities inside your data. Your whole setup is creating oddness. If that’s python code, post the whole thing.
you were right, the issue is about the boolean capital letter, it’s now working with a rough | lower
However, if i can’t graph attributes i loose one of my targets, so i fear i’ll have to setup different sensors.
Thanks for your help
For info, this is my python code generating oddness :slight_smile:
                #first part
                output = {}
                data = {}
                output['timestamp'] = time.time()
                for id, room in rooms.items():
                        if id != 0:
                                data[id] = {}
                                data[id]['roomId'] = id
                                data[id]['roomName'] = room['Name']
                                data[id]['actualTemp'] = room['Heating']['TempNow']
                                data[id]['setTemp'] = room['Heating']['TempSet']
                                data[id]['valveAperture'] = room['Heating']['Aperture']
                                data[id]['status'] = False
                                for devices in room['Devices'].values():
                                        for device in devices.values():
                                                data[id]['status'] = data[id]['status']
                publish.single(....
well, that is odd code. That device for loop is doing… nothing. Can you post the room devices dictionary?
I’ll add it to this and you can use this instead:
                output = {'data':[], 'timestamp': time.time()}
                    if id != 0:
                        output['data'].append({
                            'roomId': id,
                            'roomName': room['Name'],
                            'actualTemp': room['Heating']['TempNow']
                            'setTemp': room['Heating']['TempSet']
                            'valveAperture': room['Heating']['Aperture']
                            'status': False
                publish.single(json.dumps(output))
FYI after we make these changes, you’ll need to update your code in HA.
no, that’s my fault, i copied the code from a putty session, so just took a piece of row, the code is checking a list of device boolean fields to set the status to true if something is wrong
						data[id]['status'] = data[id]['status'] or not device['Info']['InfoValidity'] or device['Info']['Error'] or device['Info']['BatteryLow'] or not device['Info']['LinkOk']
understood your code, makes sense to avoid the nested json
Ok, so… Personally, I’d just keep room zero, you don’t need to use it.
EDIT: I see wha tyou’re trying to do with status, this should do the same thing…
                    statuses = []
                            statuses.append(
                        'roomId': id,
                        'actualTemp': room['Heating']['TempNow'],
                        'setTemp': room['Heating']['TempSet'],
                        'valveAperture': room['Heating']['Aperture'],
                        'status': any(statuses),
So now your mqtt should just be what you originally had.
Your other option is to break when it’s true…
                    status = False
                            if not device['Info']['InfoValidity'] or device['Info']['Error'] or device['Info']['BatteryLow'] or not device['Info']['LinkOk']:
                                status = True
                                break
                        'roomId': id,
                        'status': status,
