Hi all.
I am struggling with Mqtt triggers.
The solax modbus has stopped working but I also use mqtt to get data off my inverter.
I want to use my sensor that is defined as mqtt inverter temperature to trigger turning a “light” on (it’s a switch).
The mqtt value is X 10 so I used the automatic automation builder but it’s not triggering !
If you click “more info” on the sensor.solis_mqtt_inverter_temperature in the dev tools what does it show? Does it ever go above 340? Mine looks like this:
Strange. But some of the solis MQTT sensors seem to be totally wrong. Inverter Temp 363 °C, DC2 Voltage is 2346V (?). Do you use a 3rd party integration for Solis MQTT?
Is HA also running on that system? If yes, which installation type did you use and what version of raspberry pi is it? If not, on which system is HA running?
