Help with Music Dashboard view
I had this working for quite a while. I was on a mission to create a music player dashboard using alexa media player, and mini-media-player card. The weird part is in the editor it works perfectly, but once I save it, all I see is the input select. Does anyone know why?
Input select:
configuration.yaml:
input_select:
  media_player_device:
    name: Media Player Device
    options:
      - media_player.living_room_echo
      - media_player.bedroom_echo
      - media_player.office_echo
      - media_player.all_echos
    initial: media_player.living_room_echo
    icon: mdi:speaker
  media_player_device_friendly:
    options:
      - Living Room Echo
      - Bedroom Echo
      - Office Echo
      - All Echos
    initial: Living Room Echo
    icon: mdi:speaker
  media_player_devices:
    name: Media Player Devices
    options:
      - Living Room Echo
      - Bedroom Echo
      - Office Echo
      - Everywhere
    icon: mdi:speaker
Dashboard view:
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: input_select.media_player_device_friendly
  - type: custom:state-switch
    states:
      Living Room Echo:
        type: custom:mini-media-player
        entity: media_player.living_room_echo
        artwork: full-cover
        volume_step: '1'
        toggle_power: false
        show_state: true
        group: true
        hide:
          power: false
          play_stop: false
          shuffle: false
        shortcuts:
          columns: 3
          buttons:
            - name: 70’s Rock
              type: service
                name_of_music: 70s Rock From Amazon Music
                device_name: Living Room Echo
            - name: 90’s Alt
              type: service
                name_of_music: 90s Alternative From Amazon Music
            - name: Alt Hits
              type: service
                name_of_music: Alternative Hits From Amazon Music
Script
alias: play_music_on_device
sequence:
  - service: media_player.play_media
      entity_id: media_player.living_room_echo
      media_content_id: play {{ name_of_music }} on {{ device_name }}
      media_content_type: custom
mode: single
icon: mdi:music
I believe Living Room Echo in the state switch card must be enclosed in quotes, else your state switch will never match and you get the result you’re seeing.
The weird part is it works in the editor.
The editor ALWAYS shows the card (even when the state is false) so you don’t loose it in the case you’ve done what you did and the card never shows.
So you are saying to do this? If so, it removes the quotes after I save it.
entity: “input_select.media_player_device_friendly”
I’m actually flying right now and can’t edit
But the github for thomas’ card is here:
Scroll down to the section where it references Device ID. There’s multiple examples there where quotes are required because the state you’re looking for may contain a space (like the friendly name of your player)
