Help with my automation
Hey everyone I’m trying to move my automation from the config file to the automation file and I can’t seem to get if working. It worked in the config will but now it won’t work.
Here is what is in my automations.yaml file:
- id: weekday_cooldown
  alias: 'Weekday Cooldown'
    platform: time
    at: '16:00:00'
  condition:
    condition: time
    weekday:
       - mon
       - tue
       - wed
       - thu
       - fri
    - service: climate.set_operation_mode
	    entity_id: climate.nest
	    operation_mode: 'cool'
    - service: climate.set_temperature
	    temperature: '80'
Thanks for any help!
Also I’m still not sure how to use a ‘code block’ on here like other forms so the formatting is off.
just select the text that forms your code and hit the </> icon (5th from the left)
Got it thanks for the help! I’m sure my issue with the automation is a formatting error but the main automation write up on wiki doesn’t go into detail about how to use the automations.yaml just the configuration,yaml.
When you run a configuration check (eg with hassctl config) what error do you get?
Can you show us your automation section/part of configuration.yaml
Your automation has tabs on lines 17 and 18. Tab characters are not allowed in yaml code.
Sure it’s
Thanks!
Looks like that did the trick. Thanks so much for the help!
