Help with my device tracker used as condition
i need help with home/no_home switch
im using this as a switch/detection
  sensors:
    people_home:
      entity_id:
        - device_tracker.WIFE
        - device_tracker.KIDS
        - device_tracker.HUSBAND
      value_template: >-
        {{ is_state('device_tracker.WIFE', 'home')
           or is_state('device_tracker.KIDS', 'home')
           or is_state('device_tracker.HUSBAND', 'home') }}
I need this binary switch used as my condition so that i can make an automation that will turn off all my lights when no one is home ALL DEVICE IS DISCONNECTED and turn on my light if ATLEAST ONE OF THE DEVICE IS CONNECTED/HOME; my binary switch only stays on … doesn’t turn off even if all the devices are disconnected
- alias: SHUT DOWN EVERYTHING - no one is home
    platform: state
    entity_id: binary_sensor.people_home
    to: 'off'
    - service: homeassistant.turn_off
      entity_id: switch.switch_5
      entity_id: switch.switch_1
and
- alias: light (Turn on)
    platform: time
    at: '19:59:59'
  condition:
    - condition: state
        platform: state
        state: 'on'
    - service: homeassistant.turn_on
You should remove the entity_id list from your sensor and only include the value template.
Also, I’m pretty sure that the value of your sensor will be true/false not on/off.
See samples here:
I think this is overkill for what you’re trying to achieve.
Simply put the device trackers into a group, and use the state of the group for your first automation trigger and second automation condition.
hahaha true that… what the heck am i thinking… thank you thank gotta keep it simple
