Help with my first automation... turning on and off at specific times
Curious how I can make this simpe procedure a little more robust.
I have a plug I want on at 0100 and off at 2300. As is, it works.
But lets say its 0800 when I create, save, and enable this config. It wont turn on the outlet. Same if I make other changes or reboot hass for some reason it wont turn the outlet on.
Is there a way to set it so instead of exact β€œon” times its something like 0100 AND AFTER?
- alias: Outlet ON
    platform: time
    at: 01:00:00
    service: switch.turn_on
    entity_id: switch.tasmota_4
- alias: Outlet OFF
    platform: time
    at: '23:00:00'
    service: switch.turn_off
Yes it will. Next time 1am comes around.
It should already be on in that case. The state is persistent through restarts.
If it is really that critical, this automation will check every minute and turn the switch on if it is beween 1am and 11pm.
- id: outlet_on
  alias: Outlet On
  initial_state: true
    platform: time_pattern
    minutes: '/1'
  condition:
  - condition: time
    after: '01:00:00'
    before: '23:00:00'
  - condition: state
    state: 'off'
You still need your off automation.
You can also perform actions when home assistant starts using this trigger:
    platform: homeassistant
    event: start
Like this:
- alias: Outlet ON
  - platform: time
    at: 01:00:00
  - platform: homeassistant
    event: start
  condition:
  - condition: time
    after: 01:00:00
    before: 23:00:00
- alias: Outlet OFF
  - platform: time
    at: '23:00:00'
    event: start
  condition:
  - condition: time
    before: 01:00:00
    after: 23:00:00
Heres what I landed on.
- alias: Outlet ON
  - platform: time
    at: '12:00:00'
    event: start
  condition:
  - condition: time
    after: '12:00:00'
    before: '13:00:00'
- alias: Outlet OFF
  - platform: time
    at: '13:00:00'
    event: start
  condition:
  - condition: time
    before: '12:00:00'
    after: '13:00:00'
