Can anyone point me in the right direction here? I can’t get my sonoff’s with tasmota to show in HA, this is the log from my Mosquitto MQTT log.
[INFO] Setup mosquitto configuration
[INFO] Found local users inside config
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1555213185: mosquitto version 1.5.6 starting
1555213185: Config loaded from /etc/mosquitto.conf.
1555213185: |-- *** auth-plug: startup
1555213185: |-- ** Configured order: http
1555213185: Opening ipv4 listen socket on port 1883.
1555213185: Opening ipv6 listen socket on port 1883.
1555213185: Opening websockets listen socket on port 1884.
1555213185: |-- with_tls=false
1555213185: |-- getuser_uri=/login
1555213185: |-- superuser_uri=/superuser
1555213185: |-- aclcheck_uri=/acl
1555213185: |-- getuser_params=(null)
1555213185: |-- superuser_params=(null)
1555213185: |-- aclcheck_params=(null)
1555213185: |-- retry_count=3
1555213185: Opening ipv4 listen socket on port 8883.
1555213185: Opening ipv6 listen socket on port 8883.
1555213185: Opening websockets listen socket on port 8884.
1555213185: Warning: Mosquitto should not be run as root/administrator.
1555213223: mosquitto version 1.5.6 starting
1555213223: Config loaded from /etc/mosquitto.conf.
1555213223: |-- *** auth-plug: startup
1555213223: |-- ** Configured order: http
1555213223: |-- with_tls=false
1555213223: |-- getuser_uri=/login
1555213223: |-- superuser_uri=/superuser
1555213223: |-- aclcheck_uri=/acl
1555213223: |-- getuser_params=(null)
1555213223: |-- superuser_params=(null)
1555213223: |-- aclcheck_params=(null)
1555213223: |-- retry_count=3
1555213223: Opening ipv4 listen socket on port 1883.
1555213223: Opening ipv6 listen socket on port 1883.
1555213223: Opening websockets listen socket on port 1884.
1555213223: Opening ipv4 listen socket on port 8883.
1555213223: Opening ipv6 listen socket on port 8883.
1555213223: Opening websockets listen socket on port 8884.
1555213223: Warning: Mosquitto should not be run as root/administrator.
1555213227: |-- mosquitto_auth_unpwd_check(DVES_USER)
1555213227: New connection from 192.168.1.15 on port 1883.
1555213227: |-- ** checking backend http
1555213227: |-- url=http://127.0.0.1:8080/login
1555213227: |-- data=username=DVES_USER&password=Xxxxxxxx&topic=&acc=-1&clientid=
[INFO] found DVES_USER on Home Assistant
1555213230: New client connected from 192.168.1.15 as DVES_79E8D7 (c1, k15, u'DVES_USER').
1555213230: |-- getuser(DVES_USER) AUTHENTICATED=1 by http
1555213230: New connection from 192.168.1.11 on port 1883.
1555213230: New connection from 192.168.1.13 on port 1883.
1555213230: New connection from 192.168.1.8 on port 1883.
1555213230: New connection from 192.168.1.6 on port 1883.
1555213230: New connection from 192.168.1.24 on port 1883.
1555213230: |-- mosquitto_auth_unpwd_check(DVES_USER)
1555213230: |-- ** checking backend http
1555213230: |-- url=http://127.0.0.1:8080/login
1555213230: |-- data=username=DVES_USER&password=Xxxxxxxx&topic=&acc=-1&clientid=
1555213233: New client connected from 192.168.1.11 as DVES_8AB9A0 (c1, k15, u'DVES_USER').
1555213233: |-- getuser(DVES_USER) AUTHENTICATED=1 by http
1555213233: |-- mosquitto_auth_unpwd_check(DVES_USER)
1555213233: |-- ** checking backend http
1555213233: |-- url=http://127.0.0.1:8080/login
1555213233: |-- data=username=DVES_USER&password=Xxxxxxxx&topic=&acc=-1&clientid=
1555213235: |-- getuser(DVES_USER) AUTHENTICATED=1 by http
1555213235: New client connected from 192.168.1.13 as DVES_2DF2F5 (c1, k15, u'DVES_USER').
1555213235: |-- mosquitto_auth_unpwd_check(DVES_USER)
1555213235: |-- ** checking backend http
1555213235: |-- url=http://127.0.0.1:8080/login
1555213235: |-- data=username=DVES_USER&password=Xxxxxxxx&topic=&acc=-1&clientid=
1555213237: |-- getuser(DVES_USER) AUTHENTICATED=1 by http
1555213237: New client connected from 192.168.1.8 as DVES_8A9EF7 (c1, k15, u'DVES_USER').
1555213237: |-- mosquitto_auth_unpwd_check(DVES_USER)
1555213237: |-- ** checking backend http
1555213237: |-- url=http://127.0.0.1:8080/login
1555213237: |-- data=username=DVES_USER&password=Xxxxxxxx&topic=&acc=-1&clientid=
1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/HallLights/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [8AAABAABF1456D41062142B70E720AFDB23445E6] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/LivingroomLamp/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/LivingroomLamp/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [9FD42F39D2F306CBBA6F86F8459CB8342B4835C6] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/LightsBehindTheBed/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/LightsBehindTheBed/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [37EA496CA148BF705DB67375D142F51E8A52B330] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/LivingRoomLights/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/LivingRoomLights/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [49BA0B1D9FA4CB5E210421249B9826264633BE60] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, tele/FrontDoor/LWT, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, tele/FrontDoor/LWT, 2) SUPERUSER=Y by http 1555213245: |-- Cached [482D041686FDF991177B0D412422C887345FAFC3] for (client id not available,DVES_USER,2) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [C2ED30697FF38CB0FF931ABB7E7B0E55F49C46AB] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/FrontDoor/POWER, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/FrontDoor/POWER, 2) SUPERUSER=Y by http 1555213245: |-- Cached [164E94F29DD04057A3883AF279D3C281F5AECF0D] for (client id not available,DVES_USER,2) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, tele/KitchenLights/LWT, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, tele/KitchenLights/LWT, 2) SUPERUSER=Y by http 1555213245: |-- Cached [0E458E124EF9212C261A7E928792C580FA02A42E] for (client id not available,DVES_USER,2) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_8AB9A0/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_8AB9A0/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [40C2DC30DF1E904787634928BB2A346A68250B43] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_2DF2F5/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_2DF2F5/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [81422A1B55830DB3785DB4E68A76BE9BABD73586] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_8A9EF7/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_8A9EF7/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [76F0F15FBD0AE95DC906BC57267177C15FE97000] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_68D73E/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_68D73E/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [D34EADBF5EF9D3A0D99461DBB93508152CDB2AEE] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_79E8D7/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_79E8D7/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [6BD9F58A10DD186AE584A8D4A36BA7AF441875D2] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/FrontDoor/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/FrontDoor/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [1611096C44E4BC49E5C2AC125EE5D53611830A56] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/KitchenLights/POWER, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/KitchenLights/POWER, 2) SUPERUSER=Y by http 1555213245: |-- Cached [315179CD040D5F1025D5FB4335DF25F2EB5E7418] for (client id not available,DVES_USER,2) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/KitchenLights/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/KitchenLights/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [50ABE273EFFBFAFC773BC32D500ABC095314ACFD] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_804859/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_804859/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [502C19D4C4BB2D3BC658F1D300788582F47D72D4] for (client id not available,DVES_USER,4) 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/sonoffs/#, MOSQ_ACL_WRITE) 1555213245: |-- aclcheck(DVES_USER, cmnd/sonoffs/#, 4) CACHEDAUTH: 0 1555213245: |-- mosquitto_auth_acl_check(..., client id not available, DVES_USER, cmnd/DVES_808AB0/#, MOSQ_ACL_WRITE) 1555213245: |-- url=http://127.0.0.1:8080/superuser 1555213245: |-- data=username=DVES_USER&password=&topic=&acc=-1&clientid= 1555213245: |-- aclcheck(DVES_USER, cmnd/DVES_808AB0/#, 4) SUPERUSER=Y by http 1555213245: |-- Cached [D6FE956EAABFF00D8FFEAD4695322F4C4B2C006B] for (client id not available,DVES_USER,4)
