Help with netatmo weather station sensors
I’m having problems where hass.io randomly drops netatmo weather station entities which then breaks any automation which uses the netatmo entities from working.
Here is a sample from my home assistant log, maybe there’s something in here that is simple to fix but I haven’t figured out yet.
Thanks in advance for your help.
2019-05-29 19:09:05 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.netatmo_outside_temperature fails
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 220, in async_update_ha_state
    await self.async_device_update()
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 377, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 216, in update
    self.netatmo_data.update()
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 544, in update
    self.station_data = self._detect_platform_type()
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/sensor.py", line 522, in _detect_platform_type
    station_data = self.data_class(self.auth)
  File "/usr/local/lib/python3.7/site-packages/smart_home/WeatherStation.py", line 24, in __init__
    self.rawData = resp["body"]["devices"]
TypeError: 'NoneType' object is not subscriptable
