Dayve67
(Dave)
November 30, 2019, 10:18am
1
Tying to figure out how to read netdata sensors in HA. I have a few items working but can not get anything with a name that starts with “sensor” in netdata to work.
What I’m trying to get is my server CPU cord temperatures.
Here is my setup that does not work. The marked in blue does not work:
The netdata api:
angeltonio
(Angel Antonio Ravelo Batista)
May 20, 2020, 5:33pm
2
Do you can fixed???..I have the same problem.
Dayve67
(Dave)
May 21, 2020, 7:43am
3
Yes I did. I was using the wrong sensor name. Try something like this:
core0_temperature_1:
data_group: sensors.coretemp-isa-0001_temperature
element: coretemp-isa-0001_temp2
angeltonio
May 21, 2020, 7:40pm
4
And for the voltage, you know how it is???..Thanks a lot
angeltonio
May 21, 2020, 8:13pm
5
angeltonio:
I have this on my configuration.
> - platform: netdata
> host: 'localhost'
> port: '19999'
> resources:
> system:
> data_group: system.cpu
> element: system
> system.ram:
> data_group: system.ram
> element: used
> system.swap:
> data_group: system.swap
> element: used
> data_group: sensors.coretemp_isa_0000_temperature
> element: coretemp-isa-0000_temp2
and this is the Json for my netdata system
> "sensors.BAT0-acpi-0_voltage": {
> "name":"sensors.BAT0_acpi_0_voltage",
> "family":"voltage",
> "context":"sensors.voltage",
> "units":"Volts",
> "last_updated": 1590091455,
> "dimensions": {
> "BAT0-acpi-0_in0": {
> "name": "in0",
> "value": 12.1870000
> "sensors.acpitz-acpi-0_temperature": {
> "name":"sensors.acpitz_acpi_0_temperature",
> "family":"temperature",
> "context":"sensors.temperature",
> "units":"Celsius",
> "dimensions": {
> "acpitz-acpi-0_temp1": {
> "name": "temp1",
> "value": 55.0000000
> "acpitz-acpi-0_temp2": {
> "name": "temp2",
> "value": 55.0000000
> "sensors.coretemp-isa-0000_temperature": {
> "name":"sensors.coretemp_isa_0000_temperature",
> "units":"Celsius",
> "dimensions": {
> "coretemp-isa-0000_temp2": {
> "name": "Core 0",
> "value": 57.0000000
> "coretemp-isa-0000_temp3": {
> "name": "Core 1",
> "value": 58.0000000
When I put like you tell me i can´t see the sensor on home assistant…can you help me with this??..
I want temperature and voltage…regards and I´m sorry for the code format…
Dayve67
(Dave)
May 23, 2020, 8:04am
6
Sure no problem.
Should be like this for battery voltage.
BAT0-acpi-0_voltage:
data_group: sensors.BAT0-acpi-0_voltage
element: BAT0-acpi-0_in0
Temperature like this.
acpitz-acpi-0_temperature:
data_group: sensors.acpitz_acpi_0_temperature
element: acpitz-acpi-0_temp1
The first line can be what ever you want. It is the name that shows in Home Assistant.
Second line “data_group”. Copy that from where it says “name” in the api.
Third line “element”. Copy from where it says “dimensions” in the api.
The next thing is if you have more then one core temperature is to group them in a min/max sensor. let me know if you get the above working and would like see all core temperatures in one min/max sensor.
Hope this helps. Cheers
