Help with new code
Hi all.
Can anyone point out to me what is wrong with this formatting?
I’m tearing my hair out
washer_start: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-*****/commands''
--header ''Authorization: Bearer 8e3df9de-0445-4d37-afad-1111111''
--header ''Content-Type: text/plain''
--data-raw ''[
          "capability":"washerOperatingState",
          "command":"setMachineState",
          "arguments":["run"]
  washer_pause: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-*********/commands''
  header ''Authorization: Bearer 8e3df9de-0445-4d37-afad-11111111''
  data-raw ''[
          "arguments":["pause"]
washer_stop: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-*******/commands''
--header ''Authorization: Bearer 8e3df9de-0445-4d37-afad-111111''
--data-raw ''[
          "arguments":["stop"]
The **** and the 11111 are to not show my full code in case that’s not the done thing in case people can use it to hack
Error : can not read a block mapping entry; a multiline key may not be an implicit key
washer_pause is indented whereas the others aren’t.
# Washing machine
washer_start: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-14f6c92c7bec/commands''
--header ''Authorization: Bearer 8e3df9de-0445-4d37-afad-32114cbd9501''
--data-raw ''[
          "arguments":["run"]``
washer_pause: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-14f6c92c7bec/commands''
  data-raw ''[
washer_stop: 'curl --location --request POST ''https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-14f6c92c7bec/commands''
--data-raw ''[
Still the same but I notice there are no – there
When I put – there, it makes no difference
Here and other places use " not ' followed by '
That made no difference
ile ‘configuration.yaml’ could not be parsed, it was referenced from path ‘configuration.yaml’.This file will be ignored. Error(s): - YAMLSyntaxError: All collection items must start at the same column - YAMLSemanticError: Multi-line single-quoted string needs to be sufficiently indented - YAMLSemanticError: Multi-line single-quoted string needs to be sufficiently indented - - And 9 more errors…
First 2 data-raw seem to be missing the
} and ]
But There may be more.
Still no luck
This is the error
File ‘configuration.yaml’ could not be parsed, it was referenced from path ‘configuration.yaml’.This file will be ignored. Error(s): - YAMLSemanticError: Multi-line single-quoted string needs to be sufficiently indented - YAMLSemanticError: Multi-line single-quoted string needs to be sufficiently indented - YAMLSemanticError: Multi-line single-quoted string needs to be sufficiently indented - - And 9 more errors…
And this is the code
shell_command:
# Washing machine
washer_start: 'curl --location --request POST "https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-999/commands"
--header "Authorization: Bearer 8e3df9de-0445-4d37-afad-999"
--header "Content-Type: text/plain"
--data-raw "[
          "arguments":["run"]
washer_pause: 'curl --location --request POST "https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-999/commands"
--data-raw "[
washer_stop: 'curl --location --request POST "https://api.smartthings.com/v1/devices/dfe8dba1-fe99-9897-c896-999/commands"
--data-raw "[
I am sorry but there are many issues with that yaml configuration.
Where did it come from?
Have you reviewed this?
